how do they tune?
Old Dec 14, 2006 | 11:46 AM
boostin92hatch's Avatar
Default how do they tune?
ok well im a noob when it comes to getting a tune.. i just wanted to know what the basic process is.. i have searched and cant find the answer im looking for. what do they hook up to my car to get it tune and everything in order?? any help would be great. just askin cuz my car is getting tune soon and i want to know whats gonna go on
thanks
SETUP:
d15b ( jdm)
T3 super 60
440cc injectors
phearable.net ecu
blah blah blah
Old Dec 14, 2006 | 12:05 PM
blinx9900's Avatar
Default Re: how do they tune? (boostin92hatch)
**this has been copied and pasted from http://www.phearable.net**
* Tuning introduction / check list
- Before you have your vehicle tuned check list:
* Oxygen Sensor Bung: You must have a oxygen sensor bung which is accessable & installed in a proper location to where a good air/fuel pickup can be achieved. The oxygen sensor bung MUST have clean threads & be clear of any welds which may stop a larger wideband oxygen sensor from being installed into the bung.
* Fuel Pump & Injectors: You must have the proper size & type injectors & fuel pump for your vehicle setup. Please consult with your tuner to ensure you have the proper combination.
* Spark Plugs: Proper spark plugs & spare spark plugs for your application.
Please consult with your tuner if you are unsure as to what spark plugs to run.
Most sub 450 whp forced induction applications call for NGK BKR7E-11 [NGK-1283].
Most sub 450whp forced induction applications should use plugs gapped to around .028.
* Check engine light: Resolve all check engine codes before you have your vehicle tuned.
* Charge piping: Charge pipe couplings must be secure to prevent pipes from blowing off during tuning & causing delays.
* Engine compression (No more then 20psi between cylinders.)
8:1-8.5:1 c/r = 150-170 psi per cylinder 8.5:1-9.5:1 c/r = 170-210 psi per cylinder
9.5:1-11:1 c/r = 210-275 psi per cylinder 11:1+ c/r = 250+ per cylinder
* Electrical issues: Please resolve all electrical issues before tuning.
* Brakes, Suspension, Tires: All of these components are extremely important, especially if your going to have your vehicle street tuned. Please make sure they are all in good condition.
* Proper octane fuel for your application: Please inform your tuner of what fuel you are running. You should run the highest octane which is widely available in your area such as 93 octane. Try to prevent having your vehicle tuned with gas which has been sitting in your vehicle for more than 20-30 days.
* Forced Induction vehicles should invest into a pcv catch can system such as the endyne kit.
- What is required to have your vehicle tuned on Crome Pro & some other systems:
1. A vehicle/motor/setup in good mechanical condition.
2. A chipped/socketed obd1 ecu & a obd conversion harness if your vehicle requires one.
(Consult with your tuner to provide you with a chipped ecu or ecu chipping services)
3. The proper sized & resistence injectors for your application. (Ask your tuner)
92-00 Civic/Integra vehicles require Saturated HIGH RESISTANCE injectors (11-14 ohm)
LOW RESISTANCE injectors maybe used in 92-00 Civic/Integras using a resistor box.
240cc = 180-190whp 310cc = 200-220whp 370cc = 220-280whp
440cc = 280-330whp 550cc = 330whp-380whp 660cc = 380whp-425whp
720cc = 425whp-475whp 880cc = 475whp-525whp 1000cc = 525whp-600whp
4. The proper sized fuel pump. (Most street applications: Walbro 255lph fuel pump).
5. A couple of sets of spark plugs. (NGK BKR7E-N-11 for most applications under 400 whp.) Consult your tuner.
5. Optional: Fuel pressure regulator & Guage
6. Optional: Cam Gears for dyno tuning purposes.
bec1488
14
Jul 11, 2009 11:39 AM
Ldo
Jul 19, 2008 03:18 PM
vlc92189
May 5, 2008 09:38 AM
adubaz7
Sep 14, 2007 01:07 PM
pentaq
May 2, 2005 03:05 PM
