Surging Idle 1999 Civic
Old Dec 14, 2006 | 11:33 AM
TomsSVX's Avatar
Default Surging Idle 1999 Civic
Ok, I had recently agreed to work on a buddie's car. The idle will surge from 1k to 2.5k rythmically. I swapped out the idle controller on the bottom of the TB but no dice. I changed the intake gasket and TB gasket... No dice... I stuffed a rag over the opening in the TB and the idle went down and it purs like a kitten. As soon as I take the rag out... It will rev up and begin surging again. My OBDII scanner is telling me there is a malfunction in the idle controller. It pops the codes P0505 I think... ANy ideas before I just plug the hole??
Tom
Modified by TomsSVX at 12:52 PM 12/14/2006
Old Dec 14, 2006 | 11:51 AM
I Shot 50 Cent's Avatar
TPS sensor. Very common problem...i wouldnt worry about it unless it really bothers you.
Old Dec 14, 2006 | 11:53 AM
TomsSVX's Avatar
Default Re: (I Shot 50 Cent)
um... I changed the Whole TB in order to try and narrow it down and t didn't change anything... That means new TPS MAP and IAC
Tom
Old Dec 14, 2006 | 11:56 AM
Default Re: (TomsSVX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TomsSVX &raquo;</TD></TR><TR><TD CLASS="quote">um... I changed the Whole TB in order to try and narrow it down and t didn't change anything... That means new TPS MAP and IAC
Tom</TD></TR></TABLE>
No need for the idiotic "umm"...nowhere in your post did you say you changed the whole throttle body. You're welcome for the help though. Have a good time with your problem...
I'd say stick the rag in your TB, that'll take care of it
Old Dec 14, 2006 | 11:59 AM
TomsSVX's Avatar
more or less I was reflecting my thoughts at the time... It was not infering you should be able to read minds... I just wanted to explain the situation better so maybe you could help out... Sorry if I came off like a dick but it wasn't meant like that at all
Tom
Old Dec 14, 2006 | 12:00 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TomsSVX &raquo;</TD></TR><TR><TD CLASS="quote">more or less I was reflecting my thoughts at the time... It was not infering you should be able to read minds... I just wanted to explain the situation better so maybe you could help out... Sorry if I came off like a dick but it wasn't meant like that at all
All good man. Seriously though....good luck fixin the problem. Guess its not as simple as I thought.
Old Dec 14, 2006 | 08:27 PM
TomsSVX's Avatar
Default Re: Surging Idle 1999 Civic (TomsSVX)
ttt
Tom
jmpassey
Jun 7, 2018 02:34 PM
carloselpavo
23
Jun 20, 2008 08:22 AM
eskerley
13
Apr 16, 2008 02:59 PM
ITRacer121
11
Mar 25, 2005 01:49 PM
b16a1civichb
Aug 8, 2003 11:48 AM
