does a y7 oil pan fit on a y8block..?
Old Dec 14, 2006 | 11:28 AM
THEDirtyDseriesWOOT's Avatar
Default does a y7 oil pan fit on a y8block..?
does it fit..? im runnigna y7 tanny so the tranny brace thing doesent bother me.. will a nonvtec black pan fit on a d16y8 block...?
also will a z6 oil pump fit on a y8 block.. i ehard it flows more and im rebuilding from a spun rod bearing
Old Dec 14, 2006 | 12:50 PM
boostincoupe's Avatar
From: Destroying turbo ITR motors in Minneapolis, MN, U.S.A.
Default Re: does a y7 oil pan fit on a y8block..? (hitatree.at125mph)
Yes, I ran one before going to the DOHC side.
Old Dec 14, 2006 | 12:57 PM
2redstars's Avatar
y7 and y8 blocks are the same for the most part.
Old Dec 17, 2006 | 07:08 AM
Laserjock's Avatar
Default Re: does a y7 oil pan fit on a y8block..? (boostincoupe)
X3
I used a y8 pan in my Y7. I don't know about the 2nd question...bump for an answer
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostincoupe &raquo;</TD></TR><TR><TD CLASS="quote">Yes, I ran one before going to the DOHC side. </TD></TR></TABLE>
Old Dec 17, 2006 | 01:39 PM
y7turbo's Avatar
Default Re: does a y7 oil pan fit on a y8block..? (Laserjock)
oil pans are the same, i used a y7 oil pan on my y8 i just rebuilt. the oil pickup was the same as well.
i think the z6 pump will bolt on and work but you wont have anywhere to put your oil dipstick. the hole for the dipstick tube on the d16y motors is on the oil pump and the d16a/z6 motors is on the block.
Old Dec 17, 2006 | 04:23 PM
Laserjock's Avatar
Default Re: does a y7 oil pan fit on a y8block..? (y7turbo)
but remember that the Y8 is Alum and lighter than the steel Y7. Y8 will also radiate the heat better.
good info on the oil pumps. hmmm, i am rebuilding a Y8 too for spun bearings on the crank journal number 1. which bearing wnt bad? sorry for the thread jack...not really
Bense was selling a hi pressure/flow pump : https://honda-tech.com/zerothread?id=1815169
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by y7turbo &raquo;</TD></TR><TR><TD CLASS="quote">oil pans are the same, i used a y7 oil pan on my y8 i just rebuilt. the oil pickup was the same as well.
i think the z6 pump will bolt on and work but you wont have anywhere to put your oil dipstick. the hole for the dipstick tube on the d16y motors is on the oil pump and the d16a/z6 motors is on the block. </TD></TR></TABLE>
Old Dec 17, 2006 | 04:46 PM
y7turbo's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Laserjock &raquo;</TD></TR><TR><TD CLASS="quote">but remember that the Y8 is Alum</TD></TR></TABLE>
ahh i forgot that. you can still use either the y7 or y8 on the y series motors though. thats the point i was getting at.
SRd240sx
Aug 7, 2006 05:19 AM
boostincoupe
Feb 2, 2006 12:56 PM
I Have an STD
14
Dec 19, 2005 06:34 PM
