ball joint
Old Dec 14, 2006 | 11:14 AM
imskatencrzy's Avatar
Default ball joint
anyone know the easiest was to drop a lower ball joint on the front knuckle on a eg chassis?
Old Dec 14, 2006 | 11:21 AM
Mario_D's Avatar
Default Re: ball joint (imskatencrzy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by imskatencrzy &raquo;</TD></TR><TR><TD CLASS="quote">anyone know the easiest was to drop a lower ball joint on the front knuckle on a eg chassis?</TD></TR></TABLE>
What do you mean drop? Seperate from the LCA? Or remove from the spindle?
To seperate from LCA, use the big hammer technique. Or search for methods.
Removing from spindle, look here: Ball joint and wheel bearing removal
m-
Old Dec 14, 2006 | 11:52 AM
i mean to seprate from the lca? the 17 mmm nut and locking pin removed. i have pried on the bitch but its not working which areas have the best leverage?
Old Dec 14, 2006 | 12:04 PM
instructor74's Avatar
Default Re: (imskatencrzy)
Use a big hammer hit the lower control arm around where the ball joint goes through do not hit the end of the ball joint. It might take you a few hits just work around until the joint pops free
Old Dec 14, 2006 | 12:07 PM
Andres-eh2's Avatar
a giant hammer also works great for me as well. dont expletive up the threads on the balljoint
Old Dec 14, 2006 | 12:22 PM
philosofy1's Avatar
Default Re: (JJDrivesAJazz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JJDrivesAJazz &raquo;</TD></TR><TR><TD CLASS="quote">how do you use a big hammer and hit the ball joint while not messing up the threads?</TD></TR></TABLE>
because you never hit the ball joint, you're going to hit the control arm where it meets the ball joint.
this thread is actually for axle changes, but he also talks on how to take the ball joint and seprate it from the LCA:
https://honda-tech.com/zerothread?id=382416
Old Dec 14, 2006 | 02:43 PM
ok so a 4 inch 3 position puller works much better than whacking anything.
Old Dec 14, 2006 | 02:54 PM
philosofy1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by imskatencrzy &raquo;</TD></TR><TR><TD CLASS="quote">ok so a 4 inch 3 position puller works much better than whacking anything.</TD></TR></TABLE>
mmm...i wouldn't really know, but the store has a set with different sizes. just match up the size you need and get to work.
mikekc99
Jun 13, 2007 10:42 PM
chibiko
Jun 6, 2007 08:45 PM
rasinhell
32
Jan 17, 2005 04:57 PM
squeaky
14
Aug 29, 2004 12:08 PM
ultraforce77
Jul 15, 2004 02:59 PM
