Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
2001 civic headlight adjustment
Old Dec 14, 2006 | 08:38 AM
hddga76's Avatar
Default 2001 civic headlight adjustment
my dimmer switch for my headlights has apparently gone out. i have only high beams. when on dim, i only have parking lights. for a temporary fix so i don't blind others at night, how do i adjust the angle of the beam? also, how hard is it to changed the dimmer switch? i appreciate any help anyone can get.
Old Dec 14, 2006 | 09:10 AM
JesseR's Avatar
Default Re: 2001 civic headlight adjustment (hddga76)
Are you sure that your low beams are not burnt out?
Old Dec 14, 2006 | 09:42 AM
hddga76's Avatar
Default Re: 2001 civic headlight adjustment (JesseR)
no, i'm not. i was not aware that there are different bulbs for dim/high beam. i replaced the bulbs about 6 months ago to halogen. what is the liklihood that they would be shot already? i tried replacing fuses, but had no luck. i'm trying to avoid spending alot of money on labor if there may be an easy fix i can do myself. how do i check if just my dims are burnt out? thanks!
Old Dec 14, 2006 | 10:14 AM
JesseR's Avatar
The headlight bulbs are 2 ways - there are 2 filaments, one for the high beam and one for the low beam - if either goes, you have to replace the whole bulb to get it back. 6 months is not a long time for headlights to last, and it seems odd that both went out at the same time, though not impossible.
The headlights are very easy to burn out if you handled them improperly when putting them in - you should touching the glass of the headlights with your fingers - the oils from your fingers leave fingerprints which the light from the bulbs would then head up and blow out your bulb.
As far as easy/cheap fixes go, I would try replacing one of the headlights (less than $10.00), and see if that fixes it. If it does, then there is your solution (as long as it doesn't happen again soon).
I have no other suggestions for you though, I am sorry. Good luck.
Old Dec 14, 2006 | 05:23 PM
LowTec MOHawk's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hddga76 &raquo;</TD></TR><TR><TD CLASS="quote">i replaced the bulbs about 6 months ago to halogen</TD></TR></TABLE>
if you replaced them yourself and u accidently touched the glass part of the bulb with your finger or go some debris on them, then its possible that they could go out that quickly
Old Dec 14, 2006 | 08:55 PM
InanimateCarbonRod's Avatar
There is a recall on some 2001 and 2002 models where the light switch fails and you lose the low beams. Take the car to the dealer.
unclematt
Sep 1, 2016 09:39 AM
Yell0w
Aug 1, 2010 08:48 AM
biscuitjones
Nov 6, 2006 09:43 PM
UntouchableEX
May 19, 2005 07:56 AM
greensleeper
Jul 26, 2002 12:42 PM
