headlight problem...need help
Old May 18, 2005 | 03:09 PM
UntouchableEX's Avatar
Default headlight problem...need help
i had my piaa headlights for a while maybe a year or so and one night it decided to go on me...so i replaced it with an aftermarket bulb "NOKYA" funny thing is that bulb only lasted about 2 days...and its the same side that keeps blowing out...any suggestions or solutions? thanx
Old May 18, 2005 | 03:21 PM
fw190bvi's Avatar
Default Re: headlight problem...need help (UntouchableEX)
check your fuses
Old May 18, 2005 | 07:42 PM
Default Re: headlight problem...need help (fw190bvi)
yea i checked....both 20A fuses seem to be fine
Old May 18, 2005 | 08:56 PM
P_Adams's Avatar
Inadvertantly handling the glass portion of a quartz halogen bulb will cause premature failure. Seems the oils on your finger change the thermal characteristics of the glass which leads to either blistering or shattering.
One other cause might be moisture in the headlight capsule.
Old May 19, 2005 | 06:25 AM
hometheaterman's Avatar
Default Re: headlight problem...need help (P_Adams)
Were your PIAA bulbs high wattage? I don't know if they make high wattage bulbs or not but maybe if they were your wiring started meting and isn't getting a good connection and is causing the bulbs to blow. Also touching the bulb will cause it to blow but I assume you know that.
Old May 19, 2005 | 07:48 AM
90accorddx's Avatar
Default Re: headlight problem...need help (hometheaterman)
if they are the high output bulbs like silverstars or similiar they are only supposed to last about a year or at least that is what the sylvannia representative told me in an email
and are these the high or low beams
because you have no idea how many times my low beams have burnt out in my 90 dx its probably something in the wiring and definately make sure you dont let the glass touch anything
Old May 19, 2005 | 07:56 AM
Default Re: headlight problem...need help (90accorddx)
Yeah they may only last a year as thats what I have heard from others saying there lasted about that amount of time but the Nokya bulbs should have lasted longer than 2 days.
hondachris1994
Sep 2, 2010 08:10 AM
Eagle16nam
Jun 11, 2006 05:39 AM
jdmkid_82
May 23, 2006 02:43 AM
AzntstyleZ
Jan 30, 2004 11:51 AM
