if you havent done it dont reply to this: b16a block b18 crank oem stroker kit?
Old Dec 13, 2006 | 09:40 PM
spork motorsports's Avatar
* B A N N E D *
Default if you havent done it dont reply to this: b16a block b18 crank oem stroker kit?
someone mentioned it in another thread just want to know if its possible i know the b18 rods and pistons are too long, but if i get the b18 crank and throw some PR3's on it will it be just under the head enough so the valves do not meet the piston head?
Old Dec 14, 2006 | 06:33 AM
Bense's Avatar
it won't work. 77.4mm b16 stroke + 87.2 b18c crank. that's a 10mm difference, the combustion chamber isn't that large.
don't stroke it out, get a final drive instead.
Old Dec 14, 2006 | 07:48 AM
doood's Avatar
been there done that
Default Re: (Bense)
you would need custom pistons with raised wristpins if using an ls crank and rods in a b16. tech43 had a kit for this, but havent heard any progress on it.
GermanCivic
Nov 14, 2006 08:02 PM
-Gambit-
Jun 13, 2005 08:01 PM
riceball777
Feb 2, 2004 11:55 AM
Deltax75
May 20, 2002 09:03 AM
DA tegger
Jan 21, 2002 10:53 AM
