help need ifo on ls/vtec swap
i have a 95 hatch with an 95 ls motor in it i need help with vtec swap what parts do i need and info on any good web site to find parts and more info thank u
well ive done some research but some people have given different answers this is what they told me i needed
1999 Gsr Head (complete with Cams, Valves, Springs, Retainers, and Valve cover. $400.00
1995 OBD-1 P72 ECU $110.00
Vtec Solenoid $25.00
Head Bolts $30.00
Vtec Distributor $210.00
OBD-0 to OBD-1 Wire Harness $104.00
Kms B-18 Pistons $545.00
Head Gasket (95 Integra Gsr) $80.00
Water Pump (95 GSR) $45.00
GSR Timing Belt $54.00
GSR Knock Sensor $126.00
Piston Rings $140.00
Skunk2 Intake Manifold $175.00
AEM Fuel Rail 125.00
AEM fuel Regulator 150.00
Hayame Cam Gears 175.00
Golden Eagle Oil Feed Block 92.00
Golden Eagle Vtec Dowel Pins 24.00
Head Bolts $30.00
if you would have searched you would have found these two threads
https://honda-tech.com/zerothread?id=1676914
https://honda-tech.com/zerothread?id=1812388
They are killing you with that stuff, your obd1 you wont need the harness. dont ls/vtec oil line kit complete with headgasket is $150.00. get a vtec water pump,oil pump, and new timing belt. the head should run anywhere from 400-500 bucks, you can retain your own dizzy just cut off a leg or sell yours and buy a vtec one.depending on the ecu, chipped p28 most likely you wont need the knock sensor.Fuel rail/regulator waste of money. ARP rod bolts and headstuds are a must.
