ALL Motor-Usefull Gauges???
Old Dec 13, 2006 | 04:42 PM
Sassafrass's Avatar
Default ALL Motor-Usefull Gauges???
HEy, anyone here running any gauges in there car for there motor?
If so what brand? What gauge?
I'm thinkin of atleast picking up an oil pressure, but have heard negative things about them, unsafe and what not. I just want them to ensure the motor is running right and to identify any issues before its too late
Anyone have any opinions, reviews or facts to help me.
Old Dec 13, 2006 | 04:57 PM
dfoxengr's Avatar
Default Re: ALL Motor-Usefull Gauges??? (Sassafrass)
oil pressure and maybe egt.
i dont see how oil press is unsafe though.
-derek
Old Dec 13, 2006 | 05:01 PM
unknown0001's Avatar
Well I'd install a oil pressure/temp to monitor the oil in general. To keep sure what the pressure is and what the temp is of the oil in certain conditions.
If people don't recommend installing the oil pressure gauge, it's possibly because you can install the mechanical one(oil running directly to the cabin and gauge through a hose from the block) or the electronic gauge which has a sensor that goes into your block, rather then having a hose full of oil right by your feet.
Old Dec 13, 2006 | 05:09 PM
dfoxengr's Avatar
Default Re: ALL Motor-Usefull Gauges??? (Mr.RHTuner)
id definitely go for the electrical. i have the greddy oil press sitting on my shelf that i need to put in.
Old Dec 13, 2006 | 05:15 PM
Sassafrass's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr.RHTuner &raquo;</TD></TR><TR><TD CLASS="quote">Well I'd install a oil pressure/temp to monitor the oil in general. To keep sure what the pressure is and what the temp is of the oil in certain conditions.
If people don't recommend installing the oil pressure gauge, it's possibly because you can install the mechanical one(oil running directly to the cabin and gauge through a hose from the block) or the electronic gauge which has a sensor that goes into your block, rather then having a hose full of oil right by your feet.</TD></TR></TABLE>
Yea thats what I've been hearing about the mechanical gauge. Sucks the electric one costs more, but I guess you cant put a price on safety right
Old Dec 13, 2006 | 05:17 PM
117's Avatar
117
I run Defi D-Gauges. Oil pressure, oil temp, and water temp.
Old Dec 13, 2006 | 06:57 PM
JDM DERF's Avatar
oil pressure for sure
Old Dec 13, 2006 | 07:38 PM
outtacontrolsol's Avatar
Default Re: (Big Snook)
You'll want EGT for tuning and monitering your rig, too
Old Dec 13, 2006 | 08:07 PM
98vtec's Avatar
moderator emeritus
Default Re: (outtacontrolsol)
oil pressure for sure.
i got an Apexi gauge.
Old Dec 13, 2006 | 08:09 PM
b19coupe's Avatar
I like to live dangerously, only stock gauges for me
Old Dec 13, 2006 | 08:18 PM
Combustion Contraption's Avatar
If you have half a brain you get a mechanical oil pressure gauge to work just fine. completely safe.
Old Dec 13, 2006 | 08:40 PM
( o )( o )'s Avatar
Default Re: (Combustion Contraption)
other than stock, the one guage i live by is the air/fuel ratio coming from the wideband.
edit: PLX Devices, M250? i think
Old Dec 13, 2006 | 09:54 PM
smileycvc's Avatar
Default Re: (( o )( o ))
I have a mechanical oil pressure guage. No problems just be sure to run the tubing out of the way of moving parts or your pedals.
Old Dec 14, 2006 | 05:16 AM
Pondus's Avatar
Default Re: (smileycvc)
I run Defi BF meter gauges, oil temp, oil pressure and water temp. And a PLX M-300 wideband, mounted where my radio used to be so I can take a glance at the display.
Old Dec 14, 2006 | 05:27 AM
alterdcreations's Avatar
Default Re: (Pondus)
AEM A/F WIDEBAND
autometer temp, oil/water
Old Dec 14, 2006 | 06:19 AM
screaminhatch's Avatar
mechanical is more acurrate and if u put i rubber gromet around the hole in the firewall you use it wont rub a hole in the line and if u route the line with some common sense youll be fine, and like alterdcreations said, a wide band O2, doesnt even really need to be aem, even inovative would work fine
Old Dec 14, 2006 | 01:14 PM
2001B18C1GS-R's Avatar
oil pressure and air/fuel aka wideband those are teh most important i personally am going to run a aem wideband and a autometer electire oil pressures gague and oil temp for hahha's
Old Dec 14, 2006 | 02:10 PM
Big Teggie's Avatar
Oil pressure is good to have, and maybe a wideband.
ActiveAero
21
Jan 29, 2007 12:53 AM
elpiar
Oct 26, 2005 11:21 AM
CivicMike
May 26, 2005 09:34 AM
Turbo_y8
Apr 21, 2005 04:23 PM
