Secondary o2 Help GSR swap!
Old Dec 13, 2006 | 01:08 PM
silentbeatz's Avatar
Default Secondary o2 Help GSR swap!
I did a 2001 b18c1 swap on my 98 civic hb using a 1998 civic ex harness. Now the car is throwing a secondary o2 CEL. I can't find the plug for the o2 sensor on my wiring harness. Do i have to wire the sensor straight from the ecu?
Old Dec 13, 2006 | 01:24 PM
Old Dec 13, 2006 | 01:27 PM
ekb16's Avatar
u just gotta look harder...ur car should have 2 o2 sensor plugs
Old Dec 13, 2006 | 03:18 PM
nope, I only have 1 o2 sensor plug. Is it because the 98 civic ex had the 02 sensor plug behind the cup holder and not on the harness?
Old Dec 13, 2006 | 03:20 PM
chrisw85's Avatar
I thought all OBDII cars had a before and after cat O2 sensor?
Old Dec 13, 2006 | 03:28 PM
Pnoyej6's Avatar
* B A N N E D *
Default Re: (chrisw85)
im throwing the same code on my 96 ek hb with 97 usdm gsr swap. I just said screw it and converted to obd1 p72 ecu
Old Dec 13, 2006 | 03:29 PM
Pnoyej6's Avatar
* B A N N E D *
Default Re: (PnoyEj6)
i tried to fix it by welding a second 02 bung on the piping after the cat , but still throws the o2 cel
Old Dec 13, 2006 | 05:17 PM
ekb16's Avatar
get a jdm ecu if u dont want to throw that code nemore
Old Dec 14, 2006 | 08:58 AM
yup I'm already about to switch to obd1, but i also want to state ref my car, so i basically need the second o2.
Old Dec 23, 2006 | 02:03 PM
eknorcal's Avatar
Default Re: Secondary o2 Help GSR swap! (silentbeatz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by silentbeatz &raquo;</TD></TR><TR><TD CLASS="quote">I did a 2001 b18c1 swap on my 98 civic hb using a 1998 civic ex harness. Now the car is throwing a secondary o2 CEL. I can't find the plug for the o2 sensor on my wiring harness. Do i have to wire the sensor straight from the ecu? </TD></TR></TABLE>
i don't know but i thought u should be having 2 o2 sensors. maybe u did something wrong
BoneHead88
Honda Civic (2001 - 2005)
Jan 19, 2018 03:08 PM
t-del28
14
Feb 28, 2013 06:43 PM
lazii_boi08
Nov 11, 2008 05:45 PM
jdm1980
Mar 10, 2008 08:13 AM
efyou
May 26, 2006 09:27 AM
