sometime my drivers side headlight doesnt turn on
Old Dec 13, 2006 | 05:27 AM
OMG naD16 lol's Avatar
Default sometime my drivers side headlight doesnt turn on
and sometimes it does.
high beams still work. also its a cheap bulb from walmart right now... could the problem be the bulb or some wiring? (i havent touched the wiring)
Old Dec 13, 2006 | 05:49 AM
harley06's Avatar
Default Re: sometime my drivers side headlight doesnt turn on (OMG naD16 lol)
just replace the light bulb, i had the same problem
Old Dec 13, 2006 | 05:50 AM
-Gary-'s Avatar
Check the simple stuff first.
When you have your light switch on (and the light doesn't work) jiggle the wire connector and see if it comes on. If it doesn't post back and we'll continue.
****Late Edit****
It's more likely than not the light bulb.
Old Dec 13, 2006 | 09:17 AM
thats what i was thinking .... im thinking its more than likely something wrong with my fuse box, since occassionally my horn doesnt work along with my door lock actuator. so i will have to whip out the ol' voltometer on a nice day when theres a bit of free time....
Old Dec 13, 2006 | 09:19 AM
chadalac1712's Avatar
i had the same problem. when i replaced my light bulb i thought the wire in the back you plug in was all the way in. when i turned a right turn it cut on,. all i did was push on it as hard as i could it it poped into place.
98dxkoupe
May 18, 2015 01:54 AM
thunderboy
Nov 7, 2007 12:01 PM
integraracing91
Dec 3, 2006 03:43 PM
slc
Honda S2000
Oct 18, 2006 11:18 AM
niteboyzzz
Oct 4, 2002 11:24 PM
