D series ?'s
Old Dec 12, 2006 | 09:04 PM
-HONDA-'s Avatar
Default D series ?'s
okay i just picked up a D15Z1 VX motor that has (economical Vtec), well anyways i wanna start on a d series project with it HE HE...... what is all possible with the VX motor i have because i have seen here on honda tech that the VX has some - and + so what you guys think?
just trying too get ideas!
Old Dec 12, 2006 | 09:15 PM
Bense's Avatar
save the block, rods, and crank, rockers and cam. everything else is garbage.
or use 4 throttlebodies to make ITBs
Old Dec 12, 2006 | 09:17 PM
-HONDA-'s Avatar
okAY.... BUT I WANNA BUILD IT SOMEWHAT! OR MAYBE JUST ADD Bolt ons to the outside?
What other d series parts can i use on my VX motor? such as can i use the Vtec solenoid off a y8 etc..... can someone link me too a site that specilizes in D series!
Old Dec 12, 2006 | 09:19 PM
Bense's Avatar
just search for threads in this forum created by me
Old Dec 12, 2006 | 09:20 PM
sasser43's Avatar
Default Re: (-HONDA-)
Bolt ons will not help that engine. Tranny is no good. The best thing you can do is boost and tune.
Old Dec 12, 2006 | 09:25 PM
-HONDA-'s Avatar
first off! can a Y8 manifold fit on this head?
and can i just change my head to Y8 would that be better? pistons? whats the price for pistons tha will go right in without doing any boring and stuff whats a good set of pistons for this motor? and can i use a Y8 headgasket on this motor if i kept the VX head?
Old Dec 13, 2006 | 01:06 AM
thursday's Avatar
this thread should be locked ><.
this isn't 2002, D SERIES IS THE NEW B!
READ!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Old Dec 13, 2006 | 01:07 AM
GetawayInMoscow's Avatar
Default Re: (thursday)
nitrous
Old Dec 13, 2006 | 02:56 AM
GarageAlchemist
Guest
Posts: n/a
Default Re: (GetawayInMoscow)
you don't want to bore/hone ?.. you wanna reuse a head gasket, and you bought a vx engine and have no clue what so ever what you're doing.
find a new hobby.
Old Dec 13, 2006 | 09:24 AM
teal_dx's Avatar
Default Re: D series ?'s (-HONDA-)
what vehicle are you putting the motor into? do you plan to race the car or just use it for a daily driver? Depending on your budget you can do a lot, but the VX motor isn't the best foundation to build power on...
Old Dec 13, 2006 | 09:32 AM
Syndacate's Avatar
Default Re: D series ?'s (teal_dx)
Use this compression calculator to tell what your expected compressions are if you're going to be changing heads and pistons and ****.
Might wanna use a D16 block, but that's your call. Like bense said, the parts are still good off the VX tranny, but it's not the best platform for a big setup.
What are your plans? Daily driver? Weekend driver?
What are your horsepower goals?
What is your budget to work with?
Old Dec 13, 2006 | 09:35 AM
ryc555's Avatar
Default Re: D series ?'s (Syndacate)
I/H/E
Old Dec 13, 2006 | 09:55 AM
sasser43's Avatar
Default Re: D series ?'s (ryc555)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ryc555 &raquo;</TD></TR><TR><TD CLASS="quote">I/H/E </TD></TR></TABLE>
...will not help at all.
Old Dec 13, 2006 | 09:58 AM
Bense's Avatar
Default Re: (Bense)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bense &raquo;</TD></TR><TR><TD CLASS="quote">just search for threads in this forum created by me</TD></TR></TABLE>
Old Dec 13, 2006 | 01:01 PM
-HONDA-'s Avatar
i wanna make it too where it is a little stronger than the other VX motors out there! and that can take on the D16Z6/D16Y8 motors thats bout it!
Will a D16Z6 aftermarket header fit the D15Z1 block?
Also, Will the D16Z6 Intake manifold fit on the D15Z1 head? Thanks a bunch for those trying too help!
Old Dec 13, 2006 | 01:49 PM
Bense's Avatar
Why don't you help yourself and search?
Thank me later for giving you direction to be able to thank yourself.
Old Dec 13, 2006 | 03:06 PM
T-RO's Avatar
Sell your car...
Old Dec 13, 2006 | 03:38 PM
turnsignalandy's Avatar
Default Re: (T-RO)
wtf is all this negative comments. A y8 head will bolt up to your block, and will require a little drilling and wiring. Also just get a y8 exhaust manifold it should help. Then you could always get some diffeternt pistons to swap in and raise your compression, but if im not mistaken the y8 head will already raise the compression. Props on building a D series man.
https://honda-tech.com/zerothread?id=335078
https://honda-tech.com/zerothread?id=554053
here ya go man
Old Dec 13, 2006 | 03:48 PM
Bense's Avatar
Default Re: (turnsignalandy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turnsignalandy &raquo;</TD></TR><TR><TD CLASS="quote">wtf is all this negative comments. A y8 head will bolt up to your block, and will require a little drilling and wiring. Also just get a y8 exhaust manifold it should help. Then you could always get some diffeternt pistons to swap in and raise your compression, but if im not mistaken the y8 head will already raise the compression. Props on building a D series man.
here ya go man</TD></TR></TABLE>
did you read that thread? Especially this part:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BauleyCivic &raquo;</TD></TR><TR><TD CLASS="quote">Note: DO NOT ATTEMPT THIS SWAP ON A CIVIC VX, THE PISTONS HAVE TOO LARGE OF A DISH AND THE COMPRESSION WILL END UP BEING TOO LOW. </TD></TR></TABLE>
Like I said earlier....<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bense &raquo;</TD></TR><TR><TD CLASS="quote">just search for threads in this forum created by me</TD></TR></TABLE>
Since you're lazy: https://honda-tech.com/zerothread?id=1670633
Old Dec 13, 2006 | 03:51 PM
Bense's Avatar
Default Re: (Bense)
<FONT SIZE="5">D15Z1 FAQ</FONT>
https://honda-tech.com/zerothread?id=1825161
Old Dec 13, 2006 | 03:54 PM
dangthemang's Avatar
you guys should reallly listen to bense. he's like a d-series god.
Old Dec 13, 2006 | 03:57 PM
Default Re: (dangthemang)
zex 75 wet shot is like $500 and you don't have to take apart your engine. **** maybe you can even hit 200mph with the VX tranny if you have enough nitrous
Old Dec 13, 2006 | 04:16 PM
sorry bense, i dont know that much. I just knew that the Y8 has a smaller combustion chaber then other D series and figured it would raise the compresion. Thanks for clearing that up.
Old Dec 13, 2006 | 04:21 PM
Syndacate's Avatar
Run 5lbs tuned w/ a DSM SMIC.
Good for 130 or so at the wheels. You'll dick whip all the stock I/H/E Z6's & Y8's 'n ****.
EDIT:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GetawayInMoscow &raquo;</TD></TR><TR><TD CLASS="quote">zex 75 wet shot is like $500 and you don't have to take apart your engine. **** maybe you can even hit 200mph with the VX tranny if you have enough nitrous</TD></TR></TABLE>
Nah, VX tranny tops at 175.
PDRIFT86
Nov 2, 2006 12:03 PM
saber1
Jun 26, 2005 01:30 PM
circuitcivic
14
Feb 19, 2005 05:48 PM
boosted89si
Feb 2, 2005 02:11 PM
88civichbz6
Mar 2, 2004 12:24 PM
