Baker precision oil relocation kit
Old Dec 12, 2006 | 05:53 PM
92bluepreludeSi's Avatar
Default Baker precision oil relocation kit
Does anybody have this kit?
http://bakerprecision.com/honda.htm
its the third product down.
The price is not bad at all.
Old Dec 12, 2006 | 06:05 PM
es_squared's Avatar
Default Re: Baker precision oil relocation kit (92bluepreludeSi)
id like some input on it as well, was thinking of getting one
Old Dec 12, 2006 | 06:09 PM
GraphiteMW's Avatar
Looks nice and its very cheap!!
Old Dec 12, 2006 | 06:39 PM
Apex1972's Avatar
Default Re: Baker precision oil relocation kit (GraphiteMW)
Be careful, I tried a oil cooler kit like this on a H22 and could not get the proper oil pressure. Luckily I did not have to drive it. However, when I ran the motor, the oil light was on. Someone told me that V-TEC HOndas do not work well with these things. The one I tried was a B&M. It had a cooler and a relocator. In the instructions, it said if you had low oil pressure to reverse the lines to the cooler unit, when I did that , it got worse. Maybe others have had better luck but I would not do it.
Old Dec 13, 2006 | 07:33 PM
Lubo_25's Avatar
Default Re: Baker precision oil relocation kit (Apex1972)
do you really think due to the extra oil travel the pressure will go down even if you have precision -an fittings perfectly snugged on the lines and such?? is that what youre getting at??
Old Dec 13, 2006 | 07:46 PM
117's Avatar
117
The oil pressure drop is not due to just the cooler, it's due mostly to the plumbing use. You can't use small tubing without greatly restricting flow. We use -10AN on most stuff, and sometimes even -12AN. I use -12AN on my car, personally. It's overkill, but it ensures that I lose very little oil pressure (2 to 3 PSI).
That kit uses -10 lines, so you'd probably be okay. I'm not fond of using such cheap equipment on such a vital engine component (oil!), but to each their own.
Old Dec 14, 2006 | 11:42 AM
Lubo_25's Avatar
Default Re: (117)
well since there is pretty much no other method for cooling oil other than the oem oil cooler and using full synthetics i guess we're pretty much stuck in the mud or is there something else im missing??...
alperx
Dec 14, 2011 01:33 PM
Lawlergaggzorz
Jun 24, 2011 07:53 AM
SoHc94
Feb 28, 2009 03:22 PM
Supahr_Ed
May 27, 2006 11:51 AM
Black R
Jun 27, 2004 05:54 PM
