window wont go up :-(
i brought my car to get inspected, and they were ******* with fuses (who knows why) now my driver window wont go up. The passenger window works but not the drivers side...any ideas? are they on separate fuses?
i dont have power windows, but id assume they would have seperate fuses.
just pull the fuse panel to see the diagram and it should say where it would be.
was it a obd2 smog inspection?
Yes, It is 2 seperate fuses...But it is sometimes a pain in the *** to find out what goes where...and which fuses to replace.
Honestly if it were me, I would go back to the place and chew some ***...
-Rob
-Rob
haha i told em to fix it before i left, then they started tearin more fuses out so eventually i just said expletive it...GTFO and ill do it myself...i would have done more yelling but i didnt pay em anything so i didnt have to much to gain
i have obd2b, 99 ek with si power conversion, so i dont know if this applies.
check your under hood fuse, there is a 40 amp fuse that is part of your window system. also check the under dash fuse box. i dont remember the numbers exactly, but on the bottom row there should be a line of 20 amp fuses. check those, as they are for the power windows ( check the fuse cover translation to find out exactly which ones you check)
Elmor001
15
Jan 23, 2017 02:38 AM
TrueUntilDeath.com
Sep 1, 2005 04:17 AM
