Will my tires stick out/rub w/ a CRX Si rear disc conversion?
I have a set of CRX RTA's with caliper's and rotors. this swap will be going on a 90 hatch.
now ive read that the DA swap will make the rear wheels stick out a bit, but will the CRX swap do the same?
i am referring to the only thread i can find on this
https://honda-tech.com/zerothread?id=1366587
if it does is there anything i can do to avoid this? i plan on dropping the car about 2.5" so will that cause the tires to rub say with 205/50/R15's?
well this guy posted a pic of his swap from the above mentioned forum
http://www.we-todd-did-racing....x.jpg
I swapped in a rear disk conversion on my '89 HB, wheels don't stick out. I'm using 15"x7" with 195 series tires... 50K+ miles since and no problems.
Only thing I'd tell you to do while you hav the LCA's off of the car is to replace the bushings. Honda OEM available for about $28/bushing. Mine were torn, needed replacing anyway.
oh sweet so this wont be a prob then if i just use the control arms off my civic.
yes I will be replacing the bushings as well i got the ES Master kit and will be getting everything installed along with the rear discs as well as a set of skunk 2 pro s coilovers! woo hoo cant wait
thanks for the confirmation guys
Yah just use your LCA...when i picked up from the guy to use mine he had integ LCA and it seemed like it stuck out...i using my stock ones and i looks and rides fine...
fujiwaratofu86
Nov 18, 2013 07:20 PM
drew2
16
Jul 20, 2006 04:53 PM
