Removing Wrist Pins
Old Dec 11, 2006 | 11:50 PM
SaM DA Man's Avatar
Default Removing Wrist Pins
I have some LS rods with some forged SRP pistons on them. Would you suggest that i take them to a shop to remove the pins and about how much would they charg?
Old Dec 12, 2006 | 12:05 PM
BuddhaSiR's Avatar
Default Re: Removing Wrist Pins (SaM DA Man)
take it to someone that has the right tools to do that. Machine shops should be able to handle it.
Old Dec 12, 2006 | 02:38 PM
Hybrid Don's Avatar
There are special tools to press off wrist pins that the Honda Dealer has however any competent machine shop should be able to perform this task with ease.
Pressed pins require the correct tools to remove and install and some machine shops use rod heaters to expand the small end of the rod to help the pin come out.
Old Dec 16, 2006 | 07:15 PM
blackeg's Avatar
Default Re: (Hybrid Don)
if you are good at this sort of thing, id bet you can do it with some needle nose pliers, small flathead screwdriver, a vice, wrist pin sized socket and rubber mallot and perhaps a hand torch.
or you can have a machinist do it for like 40 bucks
B18aHatch
Apr 7, 2014 07:07 PM
bnmm
Jan 1, 2011 09:55 AM
dc forever guy
Mar 6, 2009 12:48 AM
flat-blk-HB
Mar 11, 2005 07:52 PM
PM-Performance
Oct 21, 2003 07:56 AM
