F/S Ls-vtec Race Motor.. BRAND NEW!! pa, del, md
up for sale is my never before used ls-vtec. alot of time and money was put into this motor and all top of the line parts. Keep in mind this motor will need to run on atleast 100 octane gas to work properly!
Now the motor:
B18b block
Bored .030 over
lightened, balanced, blueprinted crank
Eagle H-beam rods
SRP 12.5-1 compression pistons
Total seal piston rings
New oem honda bearings
ITR oil puump
ITR water pump
ITR timing belt
ITR oil pan
ITR oil pick up
Golden Eagle ls-vtec conversion kit
B16a2 head
full port and polish and 5 angle valve job done by spyder prep guinta machine
skunk 2 black nitrate coated valves
skunk 2 titanium retainers
skunk 2 dual titanium valve springs
skunk 2 stage 3 cam shafts
JE adj. cam gears
All the motor needs is a head gasket, good header, intake mani and throttle body.
Asking $5000
Pics:
http://i7.photobucket.com/albu...t.jpg
Modified by Honduh Tooner at 3:13 PM 12/17/2006
Now the motor:
B18b block
Bored .030 over
Eagle H-beam rods
ITR oil puump
ITR water pump
ITR timing belt
ITR oil pan
ITR oil pick up
B16a2 head
JE adj. cam gears
Asking $5000
Pics:
