will (96-00) civic struts fit in (92-95) civic???
Old Dec 11, 2006 | 12:33 PM
Log4n's Avatar
Default will (96-00) civic struts fit in (92-95) civic???
looking to put new struts in my older civic and wondering if they would fit?
Old Dec 11, 2006 | 01:00 PM
blinx9900's Avatar
Default Re: will (96-00) civic struts fit in (92-95) civic??? (Log4n)
fronts yes, rears depends on the company, most companies make the same rear for 92-00 and just include washers for the 96-00 cause there lca is smaller, some companies like koni actually make the u part smaller so you cant put one from a 96 on a 95 unless you spread it... good luck...
Old Dec 11, 2006 | 03:41 PM
JDM-EJ1's Avatar
Default Re: will (blinx9900)
Front will with no problem. For the rear, you may need to grind them down a bit. I would recommend getting 94-01 (DC) struts; those will bolt up no problem.
Old Dec 11, 2006 | 08:42 PM
JDMhatchback20's Avatar
Default Re: will (JDM-EJ1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM-EJ1 &raquo;</TD></TR><TR><TD CLASS="quote">Front will with no problem. For the rear, you may need to grind them down a bit. I would recommend getting 94-01 (DC) struts; those will bolt up no problem.</TD></TR></TABLE>
I would say get DC ones for the rear too unless you are getting the EK ones for cheap. I had some Tokicos from an EK that worked fine on my EG hatch, only after a little grinding down on the LCAs. I also got some KYBs that were a little harder to get to work.
So unless you are getting one hell of a deal, I'd say save yourself some work and get DC struts
batallic
Jul 17, 2008 05:51 PM
Sleepy_Red_hatch
16
May 27, 2007 07:38 PM
JDM-FREAK
Feb 26, 2005 04:31 PM
Shongku
Aug 5, 2004 09:14 PM
Dragger817
Jul 14, 2004 11:32 PM
