will (96-00) civic struts fit in (92-95) civic???
Re: will (96-00) civic struts fit in (92-95) civic??? (Log4n)
fronts yes, rears depends on the company, most companies make the same rear for 92-00 and just include washers for the 96-00 cause there lca is smaller, some companies like koni actually make the u part smaller so you cant put one from a 96 on a 95 unless you spread it... good luck...
Imperious: Mod of Valor
Re: will (blinx9900)
Front will with no problem. For the rear, you may need to grind them down a bit. I would recommend getting 94-01 (DC) struts; those will bolt up no problem.
Re: will (JDM-EJ1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM-EJ1 »</TD></TR><TR><TD CLASS="quote">Front will with no problem. For the rear, you may need to grind them down a bit. I would recommend getting 94-01 (DC) struts; those will bolt up no problem.</TD></TR></TABLE>
I would say get DC ones for the rear too unless you are getting the EK ones for cheap. I had some Tokicos from an EK that worked fine on my EG hatch, only after a little grinding down on the LCAs. I also got some KYBs that were a little harder to get to work.
So unless you are getting one hell of a deal, I'd say save yourself some work and get DC struts
Sleepy_Red_hatch
16
05-27-2007 07:38 PM
Shongku
08-05-2004 09:14 PM
Dragger817
07-14-2004 11:32 PM
