slight grind?please help
Alright i own a 2000 ek hatch with a b16b and the ctr lsd. When i am shifting into 3rd at higher rpm's there is a slick clicking noie then a 1/2 second grind noise. At lower RPM's i have no problems. Does anyone know what the issue might be? i have a slight tranny sweat that drips every now and then but could low tranny fluid cause this issue? Any help would be appreciated.
Thank you
Thank you
i promise you use this it it will take that grind right out. I had a horrible grind in 4th gear even if i put my car in 4th gear slowly it would grind bad i drained my tranny fluid and threw in 3 quarts of this and the grins was gone in 2 weeks i sware to you the additives they use are great
Alright i flushed my tranny and filled it up with penzoil syncromesh and it has become alot smoother but i still have the grind. Is it usually expected to take a while before the grind goes away? thanks for the help everybody
