More Shock travel with KYB AGX/Koni Yellows??
If I got some KYB AGX or Koni Yellows will they give me more travel? My cars lowered on Ground Control sleeves and im bottoming out. Its pretty low I cant fit a finger under the fender well front and rear. I dont want to raise it up I like it the way it sits! I read about extending your shock travel but I dont have all the proper tools to cut and weld.
help!
help!
with koni's you can do a "free mod" of lowering the front shock in the fork a bit. that gives you extra shock travel.
you can also do this mod to illuminas, but it takes a bit of cutting.
or you can just buy ground control extended top hats. they give you extra shock travel up top.
you really should just raise your car for the best handling.
EK k kay
Suspension & Brakes
13
Nov 30, 2005 11:51 AM
phantom_sol
19
Mar 5, 2004 08:52 AM
96 SOHC VTEC
24
Jan 27, 2002 07:56 PM
