Pretty sick VW, thought you guys might want to see:
Old Dec 11, 2006 | 05:11 AM
Burntrubber87's Avatar
Default Pretty sick VW, thought you guys might want to see:
Rear engine, Rear wheel drive VR6 Turbo Golf. I'm not sure if its a street car or not but I know I watched him in person running low 11's at 130+mph on street tires. I guess his best is 11.01 @137mph at Napierville dragway in Quebec.
Check out BenCustomFabric.com for more info. btw i'm in no way involved with this guy, I just though you guys would appreciate it. ?
Old Dec 11, 2006 | 06:45 AM
sohc_turd's Avatar
Default Re: Pretty sick VW, thought you guys might want to see: (Burntrubber87)
interesting.... that must crazy when the wastegate opens up.
Cruising down the stip like Cheech and Chong. haha...
Old Dec 11, 2006 | 08:41 AM
wantboost's Avatar
Who is Mr Robot?
Default Re: Pretty sick VW, thought you guys might want to see: (sohc_turd)
i dont quite get the functional point of 2 intercoolers but i do understand the asthetics.
but the way they are mounted they wont cool the charge air at all....
also, get a dumptube made
Old Dec 11, 2006 | 08:51 AM
EJ1 wilcox's Avatar
Default Re: Pretty sick VW, thought you guys might want to see: (wantboost)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wantboost &raquo;</TD></TR><TR><TD CLASS="quote">i dont quite get the functional point of 2 intercoolers but i do understand the asthetics.
also, get a dumptube made</TD></TR></TABLE>
x 2
Old Dec 11, 2006 | 09:21 AM
DaveF's Avatar
Default Re: Pretty sick VW, thought you guys might want to see: (EJ1 wilcox)
the car is lame.
Old Dec 11, 2006 | 09:50 AM
Default Re: Pretty sick VW, thought you guys might want to see: (dturbocivic)
Yeah, I think those pictures were when the car wasn't completely finished. When I saw it this summer it had a wastegate dump tube plumbed into the exhaust. ANd yeah, low 11's on street tires trapping 137, 10 second mph..I GUESS thats pretty lame.
Holy pessimist batman.
Old Dec 11, 2006 | 10:41 AM
TeamNextGenChris's Avatar
seems to me that one I/C,placed directly against the side window would make far better use of the air coming in through the vents.would also reduce charge pipe volume.maybe even a fan or two on the backside of the I/C.
chris
Old Dec 11, 2006 | 10:47 AM
Mr.E.G.'s Avatar
thats the first thing that popped into my mind.
Old Dec 11, 2006 | 10:54 AM
Mr.E.G.'s Avatar
Default Re: Pretty sick VW, thought you guys might want to see: (TeamNextGenChris)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TeamNextGenChris &raquo;</TD></TR><TR><TD CLASS="quote">seems to me that one I/C,placed directly against the side window would make far better use of the air coming in through the vents.would also reduce charge pipe volume.maybe even a fan or two on the backside of the I/C.
chris</TD></TR></TABLE>
or some ducting to route the air in and then ducting back out the rear and you wouldnt need any fans.
Old Dec 11, 2006 | 11:39 AM
Default Re: Pretty sick VW, thought you guys might want to see: (Mr.E.G.)
Well, to tell you the truth I would have mounted it basically underneath the car, like a normal FMIC, with enough stick out the bottom to work, or the I/C sitting flat with ducting running underneath it to cool it. But I guess it works ok if he's running almost 11 flat.
Old Dec 11, 2006 | 12:35 PM
Mr.E.G.'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Burntrubber87 &raquo;</TD></TR><TR><TD CLASS="quote">Well, to tell you the truth I would have mounted it basically underneath the car, like a normal FMIC, with enough stick out the bottom to work, or the I/C sitting flat with ducting running underneath it to cool it. But I guess it works ok if he's running almost 11 flat.</TD></TR></TABLE>
not trying to argue with you but theres a big difference between the high pressure area in the front bumper and an intercooler hanging underneath the car.
i do have a biased opinion as i am a huge aerodynaimcs nerd, and as such i could never bring myself to stick something under the car and in the flow of the underbody air.
i would be willing to bet that the ducting/ window setup will be considerably more efficient
CRXDrew's Avatar
atleast he has lots of room in his engine bay
Old Dec 11, 2006 | 04:08 PM
Well, i'm no engineer, So i'm not gonna' argue with you. Maybe a sti style scoop on the roof, and the intercooler right underneath..lol..
Old Dec 11, 2006 | 05:49 PM
9bells's Avatar
OG Fabricator
The car is neat. The work looks good.
It's fast because it's re/rwd.
It's all good, somebodies pride and joy!!!
Old Dec 11, 2006 | 06:28 PM
ek99's Avatar
If you look closely, both I/C have fans.
Jason703Racing
Jul 10, 2008 01:41 PM
Unidentified
Dec 23, 2007 08:43 PM
JjuuN R
Jun 14, 2007 04:11 PM
AllMotorITR
Jun 10, 2002 11:30 AM
