Rear Subframe Separation?
Old Jun 7, 2007 | 01:08 PM
JjuuN R's Avatar
Default Rear Subframe Separation?
Was just looking underneath my car and found what looks to be separation on the rear subframe, very concerned about this. What do you guys think? Maybe I'm too fast for the R.
Here's the left side which is what concerns me.
Here's the right side which seems to be holding up a lot better then the left side...
Old Jun 7, 2007 | 01:16 PM
Comp97GSR's Avatar
Default Re: Rear Subframe Separation? (JjuuN R)
y0 c-man. To me it only looks like the seam sealer seperating. Is there a crack in the weld there?
Old Jun 7, 2007 | 01:19 PM
JjuuN R's Avatar
Default Re: Rear Subframe Separation? (Comp97GSR)
Let me go get underneath it and check it out. If it is the sealer what do I do to fix it, same with it being a weld... Just re-weld it?
Old Jun 7, 2007 | 01:21 PM
Comp97GSR's Avatar
I would have a body shop reweld it if it is the weld. I palce my money on it being just the seam sealer. I used Honda bond to replace a small section like that before and it has held up.
Maybe some other OG's have some input here.
Old Jun 7, 2007 | 01:25 PM
JjuuN R's Avatar
That's good to hear, shweeew. Give me a hug? ...and by looking closer it doesn't look like a weld.
Old Jun 7, 2007 | 01:31 PM
JjuuN R's Avatar
Actually I don't even see the welds, are they under that gum type substance? The glue??
Old Jun 7, 2007 | 01:32 PM
Erik95LS's Avatar
I can't even see what you're talking about.
If you mean those little gaps where the bends in the subframe and floor meet then thats normal. Every integra I've ever looked under has those gaps.
Old Jun 7, 2007 | 01:34 PM
Comp97GSR's Avatar
Default Re: Rear Subframe Separation? (Erik95LS)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Erik95LS &raquo;</TD></TR><TR><TD CLASS="quote">If you mean those little gaps where the bends in the subframe and floor meet then thats normal. Every integra I've ever looked under has those gaps.</TD></TR></TABLE>
This is true.
Old Jun 7, 2007 | 01:44 PM
JjuuN R's Avatar
Will Honda Bond or something else keep it in place like it should be? It bugs me.
Old Jun 7, 2007 | 02:03 PM
rjgerolaga's Avatar
silicon. thats what i did. patched alot of those undernet and weird thing it stop the moisture build up.
Old Jun 7, 2007 | 02:08 PM
migs's Avatar
Default Re: (rjgerolaga)
Silicon and Honda Bond will not mate metal surfaces, just seals them from fluid.
From the pictures Cory, I can not tell what you are pointing out? Nothing looks out of the ordinary?
Old Jun 7, 2007 | 02:11 PM
JjuuN R's Avatar
Default Re: (migs)
Mike, in the first picture if you look right above the left side of the sway bar you'll see the separation.
Old Jun 7, 2007 | 03:08 PM
migs's Avatar
Default Re: (JjuuN R)
I need more pictures. I can see the GAP but not completely understanding it. I may just crawl underneath my car.
Old Jun 7, 2007 | 03:14 PM
vtec.dc2's Avatar
looks like gaps to me, it looks aligned in the middle unless i'm missing sometning, if it was separating, wouldn't be misaligned???
Old Jun 7, 2007 | 04:06 PM
JjuuN R's Avatar
Default Re: (migs)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by migs &raquo;</TD></TR><TR><TD CLASS="quote">I need more pictures. I can see the GAP but not completely understanding it. I may just crawl underneath my car.</TD></TR></TABLE>
Yeah go check yours out if you don't mind. Take a picture or two.
Old Jun 7, 2007 | 05:55 PM
Hooch'n's Avatar
R you talking about the Sway bar location......or above.
Above: All integras look like that
Sway Bar: Is that a crack going from the top of the sway bar braket towerd the center and down?
Old Jun 7, 2007 | 07:12 PM
db8sirg's Avatar
thats normal.
but this is what you would use
Old Jun 7, 2007 | 07:15 PM
db8sirg's Avatar
Modified by db8sirg at 3:58 PM 6/14/2007
Old Jun 7, 2007 | 07:22 PM
JjuuN R's Avatar
Default Re: (Hooch'n)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hooch’n &raquo;</TD></TR><TR><TD CLASS="quote">Sway Bar: Is that a crack going from the top of the sway bar braket towerd the center and down?</TD></TR></TABLE>
Wow are you seeing something I am not?
db8 thanks buddy!!
Old Jun 7, 2007 | 08:24 PM
jomama's Avatar
i don't know what to say other than maybe highlighting the area in question... i think you maaay just be a little paranoid. but are you using your baller-*** volks under your car when you jack up your car as "insurance" if the car drops??? get some other steelies under there!!! =P
Old Jun 7, 2007 | 08:27 PM
JjuuN R's Avatar
Default Re: (jomama)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jomama &raquo;</TD></TR><TR><TD CLASS="quote">i don't know what to say other than maybe highlighting the area in question... i think you maaay just be a little paranoid. but are you using your baller-*** volks under your car when you jack up your car as "insurance" if the car drops??? get some other steelies under there!!! =P</TD></TR></TABLE>
No, just sat them there for the time being. I explained the area in question pretty clearly. Everything is fine now though thanks.
Old Jun 7, 2007 | 08:58 PM
omiehomie's Avatar
sorry to gank the thread but is it possible to run the ASR sub frame reinforcement bar on a ITR? or is that just overkill?
Old Jun 7, 2007 | 10:51 PM
JjuuN R's Avatar
I was kind of pondering the same thing earlier. If it's actually possible I don't see why it would be overkill. Anyone know the answer to his question?
Old Jun 8, 2007 | 08:44 AM
JjuuN R's Avatar
Anyone know?
Old Jun 8, 2007 | 08:56 AM
Comp97GSR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JjuuN R &raquo;</TD></TR><TR><TD CLASS="quote">Anyone know?</TD></TR></TABLE>
It is not needed on the R. Those kits are for the lesser Integras and Civics.
Saw your PM last night. I was asleep but I have been staying logged on around the clock for messages.
