Which cams for my setup
Old Dec 10, 2006 | 07:46 PM
revlimitcrx's Avatar
Default Which cams for my setup
I am currently in the process of re-building my GSR.. So far I have ITR rods and CTR pistons.. At first I was afraid of the pistons cuz all I ever heard about them were negative. Sayin cuz they were cast aluminum they were weak and blah blah blah.. But after seeing jeff evan tune so many cars with em I figured whatever just try em out. I read a post stating they are safe as long as you run a big lobe cam to avoid pinging.. what cam would you recomend? Currently I have ITR cams but I am gonna sell em and get bigger...thanks for the input and advice
Old Dec 10, 2006 | 07:47 PM
I was considering Skunk 2 stage 3 , Skunk 2 Pro Series stage 2, Buddy Club 3 or 4.. or what do you guys think.. I see a lot of Skunk 2 Stage 2 cams for sale.. would these be good? Or should I get bigger...
P.S. I am gonna be running a stock headgasket or a cometic one a lil bigger then stock.. also standard compression valves not flat bottoms.. and would be running on pump gas.. thanks!!!!!
Old Dec 11, 2006 | 05:02 AM
bump!
Old Dec 11, 2006 | 08:10 AM
SkoundrelUSA's Avatar
cute little bastard
Default Re: Which cams for my setup (revlimitcrx)
You do realize your compression will now be around 13:1 right? Pretty sure you can't run pump gas. Maybe if you pull some timing but I don't know...
Old Dec 11, 2006 | 03:06 PM
13:1??? you sure about that? I highly doubt it. 12.7 highest i think.. I will be running standard compression valves (dish) not flat bottoms and a lil thicker then oem cometic head gasket with ITR rods and GSR crank in a gsr with b16 head... I was thinking it would be around in between 12:1-12:5 give or take.. I believe it is possible on pump because I have seen many dyno graphs on evans tuning website and all tuned on pump.. I just wanted to get a good size cam..
Modified by revlimitcrx at 4:18 PM 12/11/2006
Old Dec 11, 2006 | 07:16 PM
frostyrb's Avatar
Default Re: (revlimitcrx)
Why don't you ask Jeff to see what he recomends?
Old Dec 11, 2006 | 08:16 PM
choreboy's Avatar
skunk 2 stage 2 thats what we use.
Old Dec 11, 2006 | 08:18 PM
cute little bastard
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by revlimitcrx &raquo;</TD></TR><TR><TD CLASS="quote">13:1??? you sure about that? I highly doubt it. 12.7 highest i think.. I will be running standard compression valves (dish) not flat bottoms and a lil thicker then oem cometic head gasket with ITR rods and GSR crank in a gsr with b16 head... I was thinking it would be around in between 12:1-12:5 give or take.. I believe it is possible on pump because I have seen many dyno graphs on evans tuning website and all tuned on pump.. I just wanted to get a good size cam..
Modified by revlimitcrx at 4:18 PM 12/11/2006</TD></TR></TABLE>
check for your self
http://www.zealautowerks.com
Old Dec 11, 2006 | 09:37 PM
del_slow420's Avatar
Default Re: (SkoundrelUSA)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SkoundrelUSA &raquo;</TD></TR><TR><TD CLASS="quote">
check for your self
http://www.zealautowerks.com</TD></TR></TABLE>
yea i was just gettin ready to post that its not the most accuarate but its decent.. and i came out with 12.59.. not to bad im runnin 13.03:1 with my b20vtec and i run pump gas.. i am also trying to find out what the best cam would be to run in a 13:1 comp motor right now i got stock b16
Old Dec 12, 2006 | 05:36 AM
them compression calculators dont work.. they are too many variables..I spoke with Jeff and he recomened Buddy Club 4 or skunk 3 or skunk pro series 2... thanks for the input guys
Old Dec 12, 2006 | 05:38 AM
i just did the caluclator website came out to 12:7 not 13:1
Old Dec 12, 2006 | 10:51 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by revlimitcrx &raquo;</TD></TR><TR><TD CLASS="quote">i just did the caluclator website came out to 12:7 not 13:1</TD></TR></TABLE>
i said i am running 13:1 not u..
Old Dec 12, 2006 | 11:25 AM
Default Re: Which cams for my setup (SkoundrelUSA)
wasnt refeering to you delslow was talkin bout this guy who said 13:1 not you
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SkoundrelUSA &raquo;</TD></TR><TR><TD CLASS="quote">You do realize your compression will now be around 13:1 right? Pretty sure you can't run pump gas. Maybe if you pull some timing but I don't know...</TD></TR></TABLE>
Old Dec 12, 2006 | 04:23 PM
kartman's Avatar
My son just installed BC 4 in his b16 with CTR
pistons and it runs great. He also has a
skunk 2 complete valve train.
Old Dec 12, 2006 | 07:53 PM
cute little bastard
lol I don't know bout you guys, but I'm still getting 13.09:1. Its a straight GSR (B18C1 block and head) GSR crank with ITR rods (same as B18C1) and PCT (CTR) pistons you said right? Came out to 13:09
Old Dec 13, 2006 | 03:06 PM
lol I don't know bout you guys, but I'm still getting 13.09:1. Its a straight GSR (B18C1 block and head) GSR crank with ITR rods (same as B18C1) and PCT (CTR) pistons you said right? Came out to 13:09</TD></TR></TABLE>
Old Dec 13, 2006 | 03:17 PM
cute little bastard
ooo ok my bad, the first post just said GSR so thats what I thought
FASTESTCB7inQNZ
11
May 31, 2009 11:12 AM
PAndADc2
Jan 24, 2005 03:59 PM
Combustion Contraption
16
Apr 5, 2004 02:17 PM
roadawg
Dec 8, 2003 09:17 AM
Mike95lude
Aug 20, 2002 11:31 PM
