idle surging, iacv and fitv hole in tb question
Old Dec 10, 2006 | 06:05 PM
byronl's Avatar
Default idle surging, iacv and fitv hole in tb question
well i just changed my fuel filter today and about midway to the day my idle started jumping at 1k to 1.2-1.3k when the car is warmed up. Idle isn't jumping when it's cold, i took off my intake and plugged the bottom hole and felt suction, but it was little suction. When I covered the top hole, the car felt like it was about to die until i released it then idle went up and jumped again. Oh yeah, I bled the coolant and bubbles came out but the same thing.
What does this indicate? I don't think the bottom hole should be sucking at hole when it's warmed up right?
Old Dec 10, 2006 | 06:27 PM
JDM-EJ2's Avatar
Default Re: idle surging, iacv and fitv hole in tb question (byronl)
the bottom hole for the fitv (fast idle throttle valve) should not be sucking when the car is warm. it only increaces idle when car is cold to warm it up. there is a write up on cleaning it in the archives. it heips out.
https://honda-tech.com/zerothread?id=699787
Old Dec 10, 2006 | 08:05 PM
byronl's Avatar
Default Re: idle surging, iacv and fitv hole in tb question (JDM-EJ2)
yea, i've screwed that thing back before already, guess it came out a lil, time to take it out again.
Old Dec 10, 2006 | 09:08 PM
Luserkid's Avatar
If its still idling like that and you cleaned the IACV then next to do is look at the throttle body gasket and then finally the intake manifold gasket.
Old Dec 10, 2006 | 09:18 PM
byronl's Avatar
Default Re: idle surging, iacv and fitv hole in tb question (Luserkid)
so when i cover up the top hole and the car dies is normal?
Old Dec 11, 2006 | 06:39 AM
Dwight Schrute's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by byronl &raquo;</TD></TR><TR><TD CLASS="quote">so when i cover up the top hole and the car dies is normal?</TD></TR></TABLE>
yes. the top hole is for the tps. the bottom hole as mention is for the fitv. mine is bad for some reason and a new one isn't worth it as it's not even important. mine would suck air when warmed up which = bad. i took it apart, cleaned it , messed with the screw and nothing worked. i finally blocked it off and pluged the coolant line.
Old Dec 18, 2006 | 03:54 PM
bks84's Avatar
Loved
Default Re: idle surging, iacv and fitv hole in tb question (drewthomas14)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by drewthomas14 &raquo;</TD></TR><TR><TD CLASS="quote">
yes. the top hole is for the tps. the bottom hole as mention is for the fitv. mine is bad for some reason and a new one isn't worth it as it's not even important. mine would suck air when warmed up which = bad. i took it apart, cleaned it , messed with the screw and nothing worked. i finally blocked it off and pluged the coolant line.</TD></TR></TABLE>
The top hole IS not for hte TPS. Why would the TPS need vacuum? The top hole is for the IACV.
Old Dec 20, 2006 | 05:29 AM
Default Re: idle surging, iacv and fitv hole in tb question (4sd4dr)
you're right, my bad.
Tyrant_007
Mar 28, 2011 08:01 PM
spock_rocker
Oct 17, 2007 08:11 AM
SkyeC
Feb 20, 2005 10:25 PM
DelSolSi93
Sep 5, 2004 08:27 PM
steve_s
Jan 22, 2003 02:06 AM
