New Member and ive been looking/searching for the past 5 days :D
Old Dec 10, 2006 | 04:51 PM
Gatorade-E's Avatar
Default New Member and ive been looking/searching for the past 5 days :D
Hi guys:
Well I'm from Evom, but don't own an Evo or base Lancer, just on there for kicks. Anyways I've been contemplating starting a new project for myself and have found it in myself to do a DC2 JDM project. My budget is going to be around 15K and I'm looking to have a decent daily driver/autoX car. I've put together a list of parts that I could see myself buying in a couple of months to attain perfection. I'm trying to balance my parts, so feel free to comment on them! I however did not find when am I supposed to upgrade my axles on my Integra? That would be awesome if someone could tell me. As for the list of the parts here it goes:
JDM B18C1 Type-R DOHC Vtec 96-97 Integra Type-R (complete)
PeakBoost B-series Topmount Kit
Engine/Electronics:
GM 3 Bar Map Sensor -
Hondata S200 w/ Boost -
Spoon N1 Exhaust
Hasport Axles -
RC High Performance Fuel Injectors 750cc
Walbro 255HP Fuel Pump -
AEM Six-In-One Type UEGO AFR Gauge Controller -
ACT clutch
Exedy Flywheel -
Blitz Fatt -
Spoon Pistons -
Eagle Connecting Rods -
Hasport motor mounts
Suspension:
SKUNK2 suspension coilovers
Blox Sway Bar
BLOX Black Rear Lower Control Arms
Spoon Front Strut Tower Bar
Carbing Rear Lower Arm Bar
Carbing Front Lower Arm Bar
Exterior/Brakes: -
Lamborghini Black Paint -
16" ROTA GT3 Black -
Brembo Front and Rear Rotors -
EBC Front brake pads -
JDM DC2 Front end Conversion -
Honda Badge Emblem (Front & Back ) - Red Colour -
Interior: -
JDM Integra Type-R DC2 Recaro Rear Seat ITR
JDM DC ITR '96 Spec Gauge Cluster (Manual) -
Bride Brix red racing seats -
JDM Integra Type-R DC2 ITR Door Panel -
JDM Integra Type R E-Brake Handle -
JDM DC2 Honda Integra Type R Amber Clock
JDM Integra DC2 Type R E Brake Console Cover (Armrest Eliminator) -
JDM Honda Integra DC2 Type-R Carbon Fiber Climate Control, Ashtray, Air Vent, Cup Holder, Shift Plate -
JDM DC2 Integra Type Rx Pedal Set – Rare -
JDM Integra DC2 Type R Center Console Plaque 98 Spec -
JDM DC ITR Steering Wheel (Non-SRS) -
Again..I'm not trying to come up here and brag, I'm looking for decent comments about what I've chosen and what I should change or not. I've been browsing for the past 5 days and seen some people that know their **** so if you wanna comment on it, please. Thanks guys! Nice site going on.
Old Dec 10, 2006 | 05:13 PM
JDM_DC4_Fanatic's Avatar
Default Re: New Member and ive been looking/searching for the past 5 days :D (Gatorade-E)
First off, welcome to H-T. With that said, before you get flamed, the type R engine code is B15C5, B18C1 is the GSR, not a big deal, but some people freak out, also, rota's are frowned upon by some, but its up to you, so dont worry about it.
As for your parts list, thats alot of fancy names, but your missing some (IMO Obvious) things.
under the engine/electronics, you dont have cams listed? do you plan to run stock cams? if thats the case, dont bother getting a 3 Bar map sensor, cause u wont be runnin that much boost. Also, not only are you missing cams, but you dont have any valve train mods what so ever.
I also think, that for autox you would want to get a bigger brake kit. Unless by brembo, you ment the DC5 brembo conversion.
Lastly, I dont think that your budget will cover everything. B18c5 is about 5K on its own, JDM front is about another 2k for a decent one, thats half the budget on motor and front end alone. Skunk coilovers will run you atleast 800, and the N1 exhaust, if its cat back, is about another 1K, keep in mind, if you get a JDM motor, it will most likly have a JDM header, which is longer the the USDM one, so you will need to run a diffrent cat/test pipe. I also noticed you didnt have tires listed. the rotas are about 500$, and to get any kind of decent rubber for autox will also be about another 500+. I'm not trying to hate, but I think you need to re-budget or revise your list. Also, the 'type Rx' pedals arent rare, JDMLand has about 200 sets ready to ship..and I know you been surfin their site
Anyways... to end my rant, I think your project has potential, you just need a lil guidence.
Old Dec 10, 2006 | 05:24 PM
95 integra's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Gatorade-E &raquo;</TD></TR><TR><TD CLASS="quote">Hi guys:
Spoon Pistons -
Again..I'm not trying to come up here and brag </TD></TR></TABLE>
C) Spoon pistons and Eagle rods dont mix....the pistons dont have clips for full float wrist pins
D) High compression cast pistons for a turbo.....not such a wise idea
E) Turbo car for autoX and daily driver??? I think not
F) Spoon exhaust for a turbo setup?
A) Got cut
B) Also got cut
Old Dec 10, 2006 | 05:36 PM
PWJDM front clips are very expenive to ship. their oversized shipping chart is bullshit. I bought their SIR-G fenders with the sidemarkers and pigtails, and it was 200$ for shipping. theres also a bunch of little things that always add up. I'm not tring to discourage the build, just tryin to help. I'm not sure how much you know about the JDM front, or honda's in general, but, for the conversion, you need to swap out the rad support, so you MAY need a welder, some people bolt them on, which I dont think is a good idea. Also, you arent guaranteed a colour on the front end, you may get a white, black or red one. Either way, you will need to have it painted, which all costs money. and all those valve train components are pretty pricey. And you listed parts suggesting you want to boost, but you havent listed a turbo or S/C, so, whats the deal?
Old Dec 10, 2006 | 05:37 PM
Turbo_TONY's Avatar
Any 3" exhaust will work... you could go to your local muffler shop and have them fab you one...i personally went with Thermal R&D
Old Dec 10, 2006 | 05:39 PM
Turbo_TONY's Avatar
Default Re: New Member and ive been looking/searching for the past 5 days :D (Turbo_TONY)
He did say peakboost topmount..just not the turbo size
no biggie
Old Dec 10, 2006 | 05:40 PM
doood's Avatar
been there done that
for a turbo motor you're going to want low compression. if upgrading to forged internals, go with cp or wiseco pistons in 9:1 and eagle rods, unless you want to make lots of power then upgrade to pauter or manley rods. those cams you listed are more for all motor setups. stock itr cams do very well with boost so stick with those. for exhaust go with a custom 3'' setup. also you didnt mention what size turbo you'll be getting with that kit.
Old Dec 10, 2006 | 05:45 PM
Gatorade-E's Avatar
Default Re: New Member and ive been looking/searching for the past 5 days :D (JDM_DC4_Fanatic)
Oh, then I will take their shipping costs and b.s into consideration. I've been around some S15 front end conversions but I haven't really seen any Honda conversion or Honda stuff in general. The welding is no problem and installing the parts is also an "a ok" I planned on getting a beat up LS Integra and wanted to do the front end conversion right away so once it was on and up and finished I would go get it painted the dark black like I mentioned. Valve train components will come under 2K and yes it is adding up. Though, 15K isn't like a stopping point if I'm not happy (or finished), I'll just wait and overtime I will buy more parts for it. No problem with that.
I did say I want to boost and I showed you a peakboost top mount turbokit, I didn't put it in what type of turbo I was going to run but I was originally thinking of getting a T3/to4E with the supporting components.
Turbotony: I'll look into some 3'' exhausts and into some shops around here
JDM: I originally put up Lambo black..just didn't feel like writing it all out thanks though
dood: thanks for the info...im going to write that down and look into them
Modified by Gatorade-E at 7:09 PM 12/10/2006
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Turbo_TONY &raquo;</TD></TR><TR><TD CLASS="quote">He did say peakboost topmount..just not the turbo size</TD></TR></TABLE>
My bad, I missed that
Old Dec 10, 2006 | 05:47 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote"> dark black</TD></TR></TABLE>
LMAO...sry I laugh every time I see this
Old Dec 10, 2006 | 05:48 PM
Turbo_TONY's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM_DC4_Fanatic &raquo;</TD></TR><TR><TD CLASS="quote">
LMAO...sry I laugh every time I see this </TD></TR></TABLE>
Old Dec 10, 2006 | 06:15 PM
doood's Avatar
supertech valvetrain does the job without the pricetag of toda and stick with the oem timing belt
Old Dec 10, 2006 | 06:17 PM
Gatorade-E's Avatar
Default Re: New Member and ive been looking/searching for the past 5 days :D (that one doood)
Thanks dood. ^
I'll be searching up on here for more parts so i'll see you guys around !
Old Dec 10, 2006 | 06:18 PM
doood's Avatar
any other boost related questions you have, head over to the forced induction forum and read the faqs and numerous build up threads in there.
Old Dec 10, 2006 | 06:19 PM
Turbo_TONY's Avatar
you dont really NEED aftermarket axles...but they dont hurt
Old Dec 10, 2006 | 06:30 PM
Gatorade-E's Avatar
are the build-ups in the faq or are they just scattered throughout the section?
Thanks tony, I'll keep that in mind.
Old Dec 10, 2006 | 06:45 PM
Turbo_TONY's Avatar
im pretty sure they are just scattered
Old Dec 10, 2006 | 07:08 PM
dwamp2006's Avatar
so to me he's just lookin for attention
Old Dec 10, 2006 | 07:28 PM
Default Re: (dwamp2006)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dwamp2006 &raquo;</TD></TR><TR><TD CLASS="quote">so to me he's just lookin for attention</TD></TR></TABLE>
Thats ok, nobody wants your opnion
Sorry, that came out wrong...I ment, shut up
Old Dec 10, 2006 | 08:01 PM
MINTGRN4DR's Avatar
for susp with a larger swaybar look into an asr subframe brace
Old Dec 11, 2006 | 01:56 PM
Gatorade-E's Avatar
looks like someone is illiterate and can't read my last line. I have no purpose to come up here and boast and brag about what my project consists of. Thats fine if you think I'm here to brag..but this is just a forum that I look to get info from not to make friends or "brag"
I'll look into it mintgrn4dr, thanks man!
AdrenalineAngel
Northern California (Sales)
Sep 22, 2012 12:45 PM
mafay2
91
Jan 3, 2009 08:34 AM
TsukubaSpec
Feb 2, 2005 04:00 AM
