need HELP!! with integra front hub
Old Dec 10, 2006 | 04:32 PM
NeWsCr's Avatar
Default need HELP!! with integra front hub
Hey everyone, two of the studs on my passanger side hub broke off when I was trying to remove my wheel. I wanted to replace them myself and I wanted to know if their is a way I can do that. I rented a hub puller but it didn't make sence when I strted to use it. If their is anyone that has pix on how to remove the front hub post them please and also if its posible, step by step on how to remove the hub. Thanx
Old Dec 10, 2006 | 05:21 PM
JDM_DC4_Fanatic's Avatar
Default Re: need HELP!! with integra front hub (NeWsCr)
you dont need to remove the front hub. Pull the rotor off, and bang out whats left of the studs. place the new stud in from behind. Either get some washer, or some people use the rotor its self as a spacer, and 'pull' the new stud in with the lug nut. You need a spacer of some sort because you will not fully seat the new stud against the hub with the lug nut alone.
Old Dec 10, 2006 | 05:31 PM
Brick Top's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NeWsCr &raquo;</TD></TR><TR><TD CLASS="quote">Hey everyone, two of the studs on my passanger side hub broke off when I was trying to remove my wheel. I wanted to replace them myself and I wanted to know if their is a way I can do that. I rented a hub puller but it didn't make sence when I strted to use it. If their is anyone that has pix on how to remove the front hub post them please and also if its posible, step by step on how to remove the hub. Thanx </TD></TR></TABLE>
did you get a slide hammer with the hub puller?
Old Dec 10, 2006 | 06:03 PM
NeWsCr's Avatar
Default Re: need HELP!! with integra front hub (JDM_DC4_Fanatic)
Its because I tried banging it out with the hammer and it seamed to have gotten stuck where the hub goes into...I went to autozone and they told me that I need to take the hub out...because the hub housing is in the way...if it was a matter of hammering it out...I would of been done with my car...but that's not the case...and the only tool I rented out from autozone was the hub puller I thought that is all that I needed. But that does not seam to work
Old Dec 10, 2006 | 06:10 PM
NeWsCr's Avatar
By the way its a 96 integra I'm not sure if that makes a difference and the hub puller does not have have the hammer.
Old Dec 10, 2006 | 06:51 PM
Brick Top's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NeWsCr &raquo;</TD></TR><TR><TD CLASS="quote">Its because I tried banging it out with the hammer and it seamed to have gotten stuck where the hub goes into...I went to autozone and they told me that I need to take the hub out...because the hub housing is in the way...if it was a matter of hammering it out...I would of been done with my car...but that's not the case...and the only tool I rented out from autozone was the hub puller I thought that is all that I needed. But that does not seam to work</TD></TR></TABLE>
that is correct. the hub housing stops the stud from coming out all the way. so the hub needs to come off. you need to get the slide hammer also. it threads into the puller, and you slam the slider until the hub starts pulling out. the bearing case will come with it too so don't be alarmed. don't mess with the other half of the bearings. install is reverse of removal. there use to be a great write up on this, i just can't find it.
*don't forget to take off the axle nut!
Old Dec 10, 2006 | 06:59 PM
Default Re: need HELP!! with integra front hub (brick top)
you need to press the hub back into the knuckel. the stud WILL come out w/o remiving the hub, I know, i've done it. Lots of people have. A slide hammer will get the hub out, but you need a shop press to get it back in, a slide hammer, or any other tool other then a press wont do it PROPERLY.
Old Dec 10, 2006 | 07:12 PM
NeWsCr's Avatar
thanks but by hammering it out...dosnt get stuck??? Or it gets stuck for a little and then comes out?? Those are the only questions I have left. And ill try to remove it tomorrow morning...thanks again
Old Dec 10, 2006 | 07:17 PM
Brick Top's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM_DC4_Fanatic &raquo;</TD></TR><TR><TD CLASS="quote">you need to press the hub back into the knuckel. the stud WILL come out w/o remiving the hub, I know, i've done it. Lots of people have. A slide hammer will get the hub out, but you need a shop press to get it back in, a slide hammer, or any other tool other then a press wont do it PROPERLY.</TD></TR></TABLE>
[img]
removing a stud like this? not every one has the same size hub housing as you do.
and you don't have to have it pressed back in. lots of people, including myself, have slide hammered it back in. 3yrs later and its still there.
Old Dec 10, 2006 | 07:30 PM
NeWsCr's Avatar
Thanx. So the only thing I was missing was the slide hammer...that helps a lot...ill try it tommorow
Old Dec 10, 2006 | 07:35 PM
first off, I said, if you want it PROPERLY re-installed, it needs to be pressed in. 2nd, not everybody rocks extended wheel studs. Mine came out just fine on all the integra's I ever changed front studs on. I said that you COULDENT get it back in PROPERLY with a hammer, hell, you could ram it back in with a toaster, doesnt make it a good ******* idea
Old Dec 11, 2006 | 10:52 AM
Brick Top's Avatar
thats just an example of what some people do just to get the oem studs in and out.
Old Dec 11, 2006 | 01:29 PM
Sam92Teg's Avatar
[QUOTE=brick top]
[img]
Hey brick top, did the old stud scrape that spot on the hub as you hammered it out, or did you grind down the hub to make room to remove/replace the stud?
Old Dec 11, 2006 | 02:36 PM
Brick Top's Avatar
Default Re: need HELP!! with integra front hub (Sam92Teg)
i got this pic from elsewhere. they had grinded the area down to make room. but on my 96 ek, the stud hit the back hub. so i pulled the hub off. i wasn't about the grind my housing like that.
Old Dec 12, 2006 | 02:21 PM
tyco's Avatar
I see your taking it off the DB Oscar! Lol hahaha
Old Dec 12, 2006 | 03:53 PM
Brick Top's Avatar
https://honda-tech.com/zerothread?id=907985
here's the write up on the slide hammer ordeal.
Old Dec 12, 2006 | 06:34 PM
luvs2spooge's Avatar
j's racing damper for sale
Old Dec 12, 2006 | 11:11 PM
NeWsCr's Avatar
Default Re: need HELP!! with integra front hub (luvs2spooge)
MY ***** RC!!! Hahah just abiout finished with conversion just had a few problems
Old Dec 13, 2006 | 06:43 AM
tyco's Avatar
oh shiet you went through with the whole brake conversion! Wassup foo never swoop by my pad anymore! Doin your own wrench work I see!
airikkCRX
Jan 16, 2010 04:31 PM
simonEp3
Sep 3, 2008 04:49 PM
JJ's civic
Sep 29, 2006 05:01 PM
Eucalyptus lude
Apr 24, 2005 11:50 AM
typeeg
Jul 20, 2004 05:21 PM
