Headgasket
Old Dec 10, 2006 | 04:09 PM
ZXRider's Avatar
Default Headgasket
Do I headgasket on correctly or is it the other way around.
Old Dec 10, 2006 | 04:22 PM
ZXRider's Avatar
Default Re: Headgasket (ZXRider)
No one knows if it goes on this way or the other way around?
Old Dec 10, 2006 | 05:15 PM
ZXRider's Avatar
c'mon no one can help me out?
Old Dec 10, 2006 | 06:07 PM
Mikey3000's Avatar
it can only fit correctly 1 way and it looks like you have it. by the way somewhere on the surface it should say "UP".
Old Dec 10, 2006 | 06:48 PM
ZXRider's Avatar
Default Re: Headgasket (Mikey3000)
Well the problem is that only writing on it is on the bottom right corner. You can see it in the picture. And it's just some numbers.
It seems like there are 2 ways that it can fit.
One side of the gasket is all black while the other side seems to have an outline for the coolant galleys around the cylinders on the other.
I personally think I have it on correctly but paranoia is kicking in and wanted to double check.
Old Dec 10, 2006 | 07:09 PM
PrettyLude's Avatar
its correct
Old Dec 10, 2006 | 07:22 PM
ZXRider's Avatar
Default Re: (PrettyLude)
Oh ok, another problem I got now.
The dowl pins that are suposed to go on the block to hold the headgasket aligned and in spot, are they supposed to be universal? like both ends can go in the block or the head? because it seems like my dowls are fubar or something cause on both dowls one end does not want to go in either the block or the head. They were on the head I believe and the machine shop removed them for me so im starting to think maybe they did something? any input on this please.
Pic of the dowls
Modified by ZXRider at 8:33 PM 12/10/2006
Old Dec 11, 2006 | 04:23 AM
Mikey3000's Avatar
Default Re: (ZXRider)
they shouldn't be that difficult to get in the head or the block. i don't know if they are one way dowels though. the part you have a question mark by is a valve seal.
Old Dec 11, 2006 | 11:04 AM
ZXRider's Avatar
Default Re: (Mikey3000)
Well the dowls (bottom side in the pic) will no way in hell go in the block or the head, the other side has no problem tho. I wonder whats wrong...maybe I should buy new dowls and see.
Old Dec 11, 2006 | 11:16 AM
kulrevon's Avatar
the question marked part in the picture is a valve stem seal. I have no idea why it is out. You have to take retainers out to get it out.
Old Dec 11, 2006 | 11:42 AM
ZXRider's Avatar
Default Re: (kulrevon)
I had my head rebuilt, my machine shop gave me back a ziplock bag with all that stuff in it. I know what that part with the question mark is, i just posted that picture as a reference for the dowl pins...they don't fit....
Old Dec 11, 2006 | 11:53 AM
92blkJDMh22's Avatar
if you knew what it was... why is there a "?"
also, it seems funny that they gave that back to you... did they replace it? you better hope there is one in there....
britishdude's Avatar
They may have got your dowels mixed up with another customers or the whole bag of bits ? might be worth contacting the shop to see if they can shed any light. Failing that I would buy a new set of dowels at least you know they will be correct for the engine. And yes ask them to confirm they've renewed the valve seals.
Old Dec 11, 2006 | 12:15 PM
ZXRider's Avatar
Default Re: (britishdude)
Guys guys, I appriciate your input on this. I have called the shop a few days ago and talked to my machinist. They have replaced all my valve seals. He gave me that one back with my bent valve just as a reference on which one was bent.
I made a previous post about a week ago asking on honda tech what that little piece is. I just re-used the picture in this post to show you the dowl pins.
The dowl pins are about a 1 buck from honda, wouldn't hurt to just buy new ones anyway.
Old Dec 11, 2006 | 12:29 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">The dowl pins are about a 1 buck from honda, wouldn't hurt to just buy new ones anyway.</TD></TR></TABLE>
Exactly my sentiments
Thought I recognised that photo from a past post.
Old Dec 11, 2006 | 01:59 PM
ZXRider's Avatar
So I picked up 1 new dowl and ordered another one, should be here tomorrow. Local dealer charged me 2.54 for each...bastards...majestic honda has them for .86 cents. oh well.
I put the new dowl in and it works like a charm. Guess my previous dowls were damaged upon removal.
BTW gents I have another question.
Is this scratch going to cause major problems?
Old Dec 11, 2006 | 04:49 PM
117's Avatar
117
If you're lucky it won't cause a problem. You have to be very, very careful when setting the head back on the block so these kinds of things don't happen.
Unless you are very careful, the dowel pins become oval when you try to remove them, which makes them almost impossible to use.
Old Dec 11, 2006 | 05:31 PM
Dangger's Avatar
your pistons look like poo =P
ki11a8ee
Sep 1, 2005 07:23 PM
W O T
Feb 13, 2005 10:06 AM
-iLLuZioN-B18C1
Nov 8, 2004 12:53 PM
Prelude Vtec 23
May 15, 2003 08:12 AM
turboex
Jan 23, 2003 05:20 PM
