Is 2.2 the largest stroker kit available?
On the 2.2 stroker ... the bore & stroke will be increased. The largest stroker kit available on stock bore is around 1.975 litre.
2.2L is a 86mm bore and 95mm stroke (vs 87.2mm stock stroke). Thats the most you can go and most people that go with a 95mm stroke do so on a tall block (dart block or add a deck plate). If you want more displacement then 2.2L, get a different motor.
http://www.c-speedracing.com/h...c.php
nengx07
11
Feb 5, 2009 07:24 PM
GQ 05YellowEVO8
Feb 2, 2002 06:47 PM
