high egt. didnt change anything on car
Old Dec 10, 2006 | 09:33 AM
playahwitgame's Avatar
Default high egt. didnt change anything on car
suddenly, once it started getting really cold, unitl my car warms up, it looks liek i have really high egt. like 600+ degrees celicius at idle. i didnt change anything int he setup. only thinkg i can think of is maybe its so cold, the unit is malfunctioning. would the tune have any part in this, even though nothing has changed?
Old Dec 10, 2006 | 10:48 AM
memorybox's Avatar
Default Re: high egt. didnt change anything on car (playahwitgame)
well cold air is more dense, so you can cram more air in with less boost. this can cause you to run more lean and run a higher egt. I always turn boost down when its cold out because of this.
But in your situation try another unit, or test your gauge in a friends car. If the unit is ok id call the tuner. good luck
edit: corrected by 93supercoupe
Modified by memorybox at 11:59 AM 12/10/2006
Old Dec 10, 2006 | 10:50 AM
93supercoupe's Avatar
Default Re: high egt. didnt change anything on car (memorybox)
cold air is more dense.
More dense/more air/ more fuel required.
Old Dec 10, 2006 | 10:59 AM
memorybox's Avatar
Default Re: high egt. didnt change anything on car (93supercoupe)
yeah my bad got it back wards thanks for catching that
Old Dec 10, 2006 | 12:29 PM
the a/f ratio is fine. i have a wideband. its usually in the 12-13s at idle when cold
02CivicEXPhilly
Honda Civic (2001 - 2005)
Jul 1, 2008 04:54 AM
bch5428
Jan 26, 2007 07:57 PM
The_Head
Dec 15, 2002 11:28 AM
