efficient turbo for 700hp
Im looking for a turbo that will make 700hp efficiently which meaning not having to push 40 psi through it. Ive been looking at the gt4294, the turbonetics t70(offers smaller exhaust housings than the gt42) and for kicks, the gt4094r turbo. all are between 1150, and 1500$ not bad.
Ive just been seeing that you dont need 850 whp to run consistent competitive times, i feel that, that range is plenty, really no more than about 750.
84mm lsvtec 9.7:1, ported head, all the little goodies. air to air.
i have a GT45R and i am trying for 550 whp on 17 psi...im sure that this turbo would easily hit 700 whp with 25-30 psi...i will let you know what i make though soon...it should be on the dyno within the next week or so.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by yellow munson »</TD></TR><TR><TD CLASS="quote">where can you buy GT4094R for 1500 . post up site
I thought turboelement was cheapest</TD></TR></TABLE>
well thats what i meant, CLOSE ENOUGH LOL!!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BoostGoneWild »</TD></TR><TR><TD CLASS="quote">I'm also intrested!.. Do they make the gt4094 nonBB????
no they dont, i already tried that. I WISH.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Cpres »</TD></TR><TR><TD CLASS="quote">i have a GT45R and i am trying for 550 whp on 17 psi...im sure that this turbo would easily hit 700 whp with 25-30 psi...i will let you know what i make though soon...it should be on the dyno within the next week or so.</TD></TR></TABLE>
thanks butt i need to stay within the SFWD 72mm NHRA limits.
After duing some research, I have a similar setup as yours,
im going with the gt4292 non BB
i found one for $1100
reason? its 900 cheaper then the BB one and a spool difference of 300rpm...
can you spin your past 10k?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Cpres »</TD></TR><TR><TD CLASS="quote">i have a GT45R and i am trying for 550 whp on 17 psi</TD></TR></TABLE>
better i made 600whp+ on 17lbs with smaller turbo!
Here we go again, more Idaho.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dual Cam Racing »</TD></TR><TR><TD CLASS="quote">u can use the new gt40r thats out or the t3/t67</TD></TR></TABLE>
umm no, i said efficiently. maybe on a supra will that turbo efficiently make 700. I know some would argue that though. If im going to buy a gt40R its gonna be a gt4094r
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fmfkid250 »</TD></TR><TR><TD CLASS="quote">After duing some research, I have a similar setup as yours,
can you spin your past 10k?</TD></TR></TABLE>
nah, i could but there is no point. 9500
do you mean the gt4294??
innovative is alright, they seem to be a little laggy, and expensive.
i thought about a netics t70 with the .70 turbine housing, or the .82
find me a dyno graph of a 700+ whp honda on a t3/t67 or t4/t67 without nitrous and not near 40 psi. I know of only one personally.
Find a compressor that will flow 70lb/min at ~70% compressor efficiency. Its not that difficult...
http://www.turbobygarrett.com/....html
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jared »</TD></TR><TR><TD CLASS="quote">why are you so concerned with running such low boost and making that horsepower? why buy a turbo and not use all of it?</TD></TR></TABLE>
x2
x2
http://www.not2fast.com/turbo/...shtml
According to that calc, difference between 15psi and 30psi will be an increase in temps of about 140*. Probably why he wants to get a more efficient turbo than not.
im not wanting to run low boost unless you arent talking to me, i just want to find a turbo that will make 700 by around 35psi. I dont want to run 40 psi with hot *** temps to crack 700hp because that is silly.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SPOOLINmatt »</TD></TR><TR><TD CLASS="quote">i just want to find a turbo that will make 700 by around 35psi.</TD></TR></TABLE>
the t67 should make that power at that boost level? IF u are a effiecent setup. cant just take a **** box and throw turbo on it and expect to make 700whp.
chris
chris
