Y7's oil pressure
Old Dec 10, 2006 | 07:22 AM
Project_DX's Avatar
Default Y7's oil pressure
So i had a D15B7 that i turbod and tuned for 12psi....i set it at 10psi to be safe....well after a year of getting beat on it finaly blew...
...i swaped in a Y7 bottom end that i had laying around in my basement...everything runs smooth....although i noticed my oil press was runnin around 25psi at 4K warm???? my B7 would be at 25psi at idle and about 70psi at the higher rpms...
...now i have search on shimming the spring in the oil pump to up press, but i did come across something about shimming the pressure relief valve to up it by 10psi...first question is where is the pressure felief valve at...2nd what would be better to do, shim the spring or the valve, and who has actually done this and seen a raise in press...oh ya i'm runnin royal purple 10w40 thanks-Pat
Old Dec 10, 2006 | 07:35 AM
Project_DX's Avatar
Default Re: Y7's oil pressure (Project_DX)
up...
Old Dec 11, 2006 | 05:44 AM
Project_DX's Avatar
bump... anyone???
Old Dec 11, 2006 | 09:18 AM
fjt's Avatar
fjt
mine ran at 20psi at iddle...sometimes a lil lower..
What really matters is that when you floor it the oil pressure rises quickly.. Mine went up to like 80 at Full Throttle and 18PSI of boost
Old Dec 11, 2006 | 12:44 PM
EK k kay's Avatar
Default Re: (fjt)
Yeah my y7 bottom end sees very little oil pressure at idle, but once you blip the throttle even slightly it shoots up to 50psi.
slammedz6ef
Feb 27, 2008 09:18 AM
slammedz6ef
23
Feb 26, 2008 05:47 PM
Project_DX
10
Dec 12, 2006 06:42 AM
99B16Si
Apr 7, 2004 08:22 AM
