Does anyone know how to.. city lights
so i wanted to hook up some city lights in my 00 ek but dont know how or what i need. can some one point me in the right direction where i can read about how to hook them or show me, and also what do i need?? thanks!
WEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEE EEEEEEEEE
umm.. "points up"
seee " ***Post Links to Helpful FAQs So We Can Get an Archive Going***"
that sticked stuff, at the top of the forum!!!
look there first b4 asking any questions...
and the search link, in red.. top right hand corner..
umm.. "points up"
There's two main ways to do it:
1) Stock/JDM style:
Positive to 12v on corner light
Negative to Ground on corner light
2) On/Off Style
Negative to 12v Low-Beam on headlight
Method 1 will keep the city lights on as long as your corner lights are on, and will stay on when your headlights are on.
Method 2 will turn the city lights on with your corner lights, and turn them off when your headlight comes on. They will turn back on with high-beams, but nobody will see that, because you're supposed to turn your high-beams off around other people
1) Stock/JDM style:
2) On/Off Style
Method 3: Hook them up to some universal foglight harness. I mounted the switches on the block off plates in the armrest.
Go to Autozone and find the cheapest foglight harness they have. It will be much cheaper than buying individual wires, switches, fuses, etc. if I remember correctly the harness cost $7.99. It's by Pilot Automotive, and it includes the wiring and switch. I forgot if it came with a fuse holder or not, and it did not come with a relay.
Since you have a 2000 Civic, you can buy the Soei city light kits that have a ring mount to place on the base of your 9003 or H4 bulb. That way you won't have to drill an additional hole to install a city light bulb.
Let me know if you have more questions.
Modified by White95SiHB at 2:07 PM 12/10/2006
Accord City Lights https://honda-tech.com/zerothread/1780175
S2000 City Lights https://honda-tech.com/zerothread?id=1824027
Integra City Lights https://honda-tech.com/zerothread?id=1716378&page=1
There is a few that I got with just the HT search. So, it does work! Who knows what you would find with Google
Vampire2o9
Aug 12, 2009 12:11 PM
99delsol
Aug 24, 2006 09:57 PM
jes c
25
Sep 17, 2004 03:26 AM
