pcv valve replacement question
Old Dec 9, 2006 | 03:14 PM
chrimy90cx's Avatar
Default pcv valve replacement question
hey i have been searching for a while now and i cant seem to find any answers! so ill ask the pros. How hard woudl it be to change this myself on my d15b2?? can i do this myself or shoudl i take it to the garage i am minimul skills can change oil spark plugs etc. Anyone have a link to help me .
Thank you all in advacne.
Old Dec 9, 2006 | 03:26 PM
blah13's Avatar
Default Re: pcv valve replacement question (chrimy90cx)
Disconnect hose, remove pcv valve, put in new valve, replace hose. Thats $80.
Old Dec 9, 2006 | 03:37 PM
chrimy90cx's Avatar
Default Re: pcv valve replacement question (blah13)
sounds simple where do i located the hose i can only find info in newer motors where you have to remove the oil filter to get to it
thank you
Old Dec 9, 2006 | 04:03 PM
blah13's Avatar
Honestly off the top of my head I cant remember for sure on the d15b2, I know on the a6 its between the two intake runners on the right, behind the valve cover. Check there for a hose that runs into the intake.
Old Dec 9, 2006 | 04:06 PM
HondaHeddie's Avatar
the pcv on the DPFI is located in the middle of the manifold
it is at the end of the hose that comes from below and makes a turn to connect to it.
Like a umbrella handle or an upside down J
Old Dec 9, 2006 | 04:13 PM
chrimy90cx's Avatar
Default Re: pcv valve replacement question (HondaHeddie)
sweet thanx u guys im heading out now to atempot to change it
thanks for the help!
Old Nov 17, 2013 | 04:55 PM
smichka's Avatar
huh is it a good or a bad idea to remove the pcv valve on this engine ?
or should i put catch can system
Old Nov 18, 2013 | 04:46 AM
Freemananana's Avatar
Keep the PCV on the motor. The V stands for valve I think. Kind of like save the El Camino. The The Car. Haha, anyways! Keep it, it does an important job. Catch cans are good on boosted set ups that will be getting more blow by and such. Shouldn't need it on a NA motor. At least that's my understanding.
Lastly, what a weird ancient bump. At least you are searching.
Old Nov 18, 2013 | 01:19 PM
smichka's Avatar
Tnx for the replay
Well tomorrow i will setup the pcv valve
I'm planning to change the valve and clean the hose then put some can to gather the oil if there is any and to close the hole from the intake manifold
If that doesen't works
Then catch can system without breather cause that's the most stupid system i've ever saw,letting some air out and some in,that doesn't works for me
I'll put in-line fuel filter on the hose after the catch can and hope that will get some kind of filtration
Tommorow with pics and opinion about the 2 options
vteg98
Oct 24, 2006 07:05 PM
x91civichatch
Nov 14, 2005 03:21 PM
dukwei
May 13, 2005 06:05 AM
byronl
Mar 19, 2005 10:24 PM
civicbuny
Jan 4, 2005 03:23 PM
