Rumbling noise from drivers side
a wheel bearing will make a high pitch squeel, and is usuially there all the time while the wheel is turning. Could you better describe the "rumbling" noise?
I only hear it when im turnin the wheel right. its kinda like virbrating noise, i know i need new rotors, just havent got around to changing them, could that be what im hearing?
it could be rotors ONLY if it makes a noise when you hit the brakes. A wheel bearing wouldent vibrate, unless its soo bad its about to fall out. My guess is ball joint. when you turn, there is extra stress put on them.
Blastek
Oct 18, 2004 08:34 AM
