tranny drain plug
Old May 10, 2002 | 08:06 PM
lmscagain's Avatar
Default tranny drain plug
Ok, call me dense. Is there some trick to finding & removing the tranny drain plug? car is on ramps, & I still can't find the darn thing. Any special tools to use? Swaping engines tomorrow & need info asap. Thanks
Old May 11, 2002 | 05:28 AM
Mista Bone's Avatar
D Tranny Guru
Default Re: tranny drain plug (lmscagain)
3/8" ratchet is all you need.
Go for the little bolt, the big 30mm plug is for access to the countershaft lockring.
Old May 11, 2002 | 04:46 PM
snkypete's Avatar
New User
Default Re: tranny drain plug (Mista Bone)
i was trying to change my tranny fluid today and i couldn't get the damned filler bolt out.. the reason i was doing the filler first and not the drain is because if i had drained the tranny and not able to take off the filler...that would be a little bit of a problem
so i ended up not doing it
i have to find a way to get that damn bolt loose
Old May 11, 2002 | 04:52 PM
lmscagain's Avatar
Default Re: tranny drain plug (huk)
So far, got the tranny drained, engine out with minor damage to the radiator, but still am not sure which one is the filler bolt for tranny. Pictures from the manual suck! If you can zero me in & I find an easier way to get it out, I'll let ya know.
Old May 11, 2002 | 05:00 PM
livent's Avatar
On the side of the trany where it bolts up to the motor, along the bottom you will see a 3/8 rachet fitting, loosen and voila!!!
Old May 11, 2002 | 06:31 PM
94gsr's Avatar
On my Integra, if you're sitting on the ground, facing the passenger side of the car, looking at the tranny, the filler bolt is the 17mm bolt to the left & just slightly below where the passenger axle goes into the tranny.
Old May 11, 2002 | 10:51 PM
TypeSH's Avatar
Default Re: tranny drain plug (94gsr)
On my accord, it was nearly impossible w/ just a ratchet or wrench. I ended up using a 24" breaker bar to loosen it (which did it very easily).
Old May 12, 2002 | 04:27 AM
Prelude Vtec 23's Avatar
On my prelude, the filler bolt is above and to the left of the drain plug, dont know if it is the same on you integra but it seems like it.
Old May 12, 2002 | 02:09 PM
lmscagain's Avatar
Default Re: tranny drain plug (Prelude Vtec 23)
FOUND IT! would not have been able to with the engine in. The wheel was in the way. Thanks for all your help. Now to put the other one back in! Ha
Old May 12, 2002 | 04:14 PM
Bror Jace's Avatar
For the uninitiated, I recommend loosening the filler/check bolt first. There is no point in draining the oil if you are unable to re-fill it.
--- Bror Jace
Old May 13, 2002 | 04:58 AM
Mista Bone's Avatar
D Tranny Guru
Default Re: tranny drain plug (Bror Jace)
17mm box wrench and a hammer.
Yes I did, 10+ times so far! How that filler bolt get so damn tight?????????
Old May 13, 2002 | 08:29 AM
Crazydave's Avatar
impact wrench always works
just watch out when the fluid comes!
JASIYAH6
Mar 9, 2009 10:05 AM
midnitesol
Jan 20, 2007 05:44 PM
H22A4Me
Jan 27, 2006 07:55 PM
trooper0641
Feb 4, 2005 04:15 AM
ludelvr
Aug 22, 2003 03:56 AM
