idle setting jumper(to be or not to be)
Old Dec 8, 2006 | 01:54 PM
HondaHeddie's Avatar
Default idle setting jumper(to be or not to be)
I have searched and seen opinions go about 50/50 that jumpering the connector on the passenger side makes a difference when setting idle speed
what do you guys currently feel, and does anyone have a definitive description of what it will/wont do if not jumpered?
also I am using the USDM crank pulley on my JDM D15B(NOT vtec)
do the timming marks match or should I "interpret" them?
Old Dec 8, 2006 | 02:13 PM
Perfectionist's Avatar
Default Re: idle setting jumper(to be or not to be) (HondaHeddie)
To set the base idle, you unplug the IACV on a warm engine and adjust the bypass screw to achieve the specified base idle. To set timing, the test connector has to be jumpered.
Old Dec 8, 2006 | 02:22 PM
Default Re: idle setting jumper(to be or not to be) (Perfectionist)
ok sorry for mixing the question,
thanks for the answer on the idle setting
I have continued this thread under a clearer heading here :
https://honda-tech.com/zerothread/1832400
Modified by HondaHeddie at 5:35 PM 12/8/2006
turbohatch96y7
Engine Management and Tuning
Jun 10, 2013 07:42 AM
raverx3m
Mar 24, 2013 09:19 PM
Elvis1977
Apr 1, 2009 04:13 PM
invasian_boy
Jul 15, 2008 12:59 PM
