Advise: Air in clutch lines?
Old Dec 7, 2006 | 07:13 PM
garyc17's Avatar
Default Advise: Air in clutch lines?
What are the symptoms of air trapped in clutch lines? Is a stuck clutch pedal to the floor one of them? It happened to me yesterday but its all good today. Checked for leaks but there are no signs along the hydraulic lines and short rubber hose section. Clutch reservoir is still full and there are no leaks at the firewall in the car and no leaks at the slave cylinder. Any advise appreciated.
Old Dec 7, 2006 | 07:26 PM
migs's Avatar
Default Re: Advise: Air in clutch lines? (garyc17)
This can be symptoms of a bad master and/or slave cylinder. Depending on mileage of your vehicle, I personally would replace it out of preventative maintenance AND to gain that "new car" feel again.
Old Dec 7, 2006 | 08:12 PM
MidwestSiR's Avatar
Also.. The omni Quick Clutch Master Cylinder is a nice upgrade if you're replacing the MC.
Just something to look into
Old Dec 7, 2006 | 09:28 PM
Erik95LS's Avatar
Have you tried bleeding it yet?
Old Dec 8, 2006 | 09:58 PM
garyc17's Avatar
I have yet to bleed it. The problem happened for about 5 mins few nights ago. It has not reocurred yet.
RDAYA0
Dec 14, 2006 05:31 PM
puertoroc7976
Sep 7, 2006 03:06 PM
byronl
May 2, 2006 07:53 PM
civiceg500
18
Aug 16, 2004 06:11 PM
