what should i use to bend pipes(anything cheap)
Old Dec 7, 2006 | 11:47 AM
quicknadc2's Avatar
Default what should i use to bend pipes(anything cheap)
i wanna bend some pipes to build a roll cage but i dont want to go to a shop for the bends so i was wondering if anyone has any ideas on how to bend for cheap.Thanks in advance.
Old Dec 7, 2006 | 11:56 AM
quicknadc2's Avatar
Default Re: what should i use to bend pipes(anything cheap) (QUICKNADC2)
bump.
Old Dec 7, 2006 | 12:02 PM
Brent L's Avatar
bend some condoit to the shape you need it then find someone with a bender to bend you those shapes..i did a whole tube frame car that way
Old Dec 7, 2006 | 12:41 PM
densetsu's Avatar
Default Re: (Brent L)
build your own!
http://www.metalwebnews.com/ho....html
Old Dec 7, 2006 | 01:09 PM
Bjorn's Avatar
weld end cap on pipe, fill with sand, pack it in tight, weld cap on other end, dent in caps to pack sand in tighter, bend
google sand bending
edit - doh, I forgot, don't do it for cage
Old Dec 7, 2006 | 02:23 PM
quicknadc2's Avatar
thanks for the replys.
Old Dec 7, 2006 | 09:45 PM
RCautoworks's Avatar
Default Re: (QUICKNADC2)
Cage, and cheap should never be used in the same sentence.
Old Dec 7, 2006 | 10:27 PM
9bells's Avatar
OG Fabricator
What kind of tubing are you using?
I hope you are not using pipe...
Should be DOM, 1 3/4".
"Cage, and cheap should never be used in the same sentence. "
Couldn't agree more. Would you buy a bargain basement air bag system?
Old Dec 8, 2006 | 12:21 AM
RC000E's Avatar
Default Re: what should i use to bend pipes(anything cheap) (9bells)
they had a thread last week about a pre-made weld together cage for pretty cheap as long as your chassis is supported. That's the route I would go.
Old Dec 8, 2006 | 10:04 AM
sharkytm's Avatar
Call up SW Racecars. They will bend you a main hoop for VERY short money, and it'll be stronger than anything you could do yourself on some hackjob DIY machine. Heck, they'll build you a full cage so long as you get them the dimensions they need. They are great people who I've dealt with a bunch. Don't trust your safety to a "cheap" solution.
hoochhenry
Welding / Fabrication
Dec 16, 2011 04:02 AM
ViZ
18
Apr 17, 2004 02:24 PM
machgo5go
Feb 18, 2004 03:27 AM
mattb16a1civic
35
Nov 11, 2003 11:20 AM
Boostless97Lude
Feb 15, 2003 03:08 PM
