ppl running pr3/pw0 on d15b/d16 vtec
Old Dec 7, 2006 | 03:31 AM
zenon8890's Avatar
Default ppl running pr3/pw0 on d15b/d16 vtec
hi there, whats the results of running pr3/pw0 on a d15/d16 vtec?! i know i'll have o2 sensor code and knock sensor code too, any other problem can occur?! how's the performance?!
i'm buying one cheap today so plz help
Old Dec 7, 2006 | 09:52 AM
N_A_is_best's Avatar
Default Re: ppl running pr3/pw0 on d15b/d16 vtec (zenon8890)
ive done it before it worked for me just knock that u ground to the chassis and 2nd o2
Old Dec 7, 2006 | 11:03 AM
HondaPartsHero's Avatar
Technical Hero
Default Re: ppl running pr3/pw0 on d15b/d16 vtec (N_A_is_best)
you can do one of two things:
1. Run a knock and have a 2nd O2 bung welded up and run another O2
2. Have the ECU chipped to remove the knock sensor/ 2nd O2
The knock sensor looks for voltage so you can't just ground it. Same goes for the O2
Old Dec 7, 2006 | 02:47 PM
zenon8890's Avatar
thanks man, what about vtec and performance?! does it run better than the pm6?!
Old Dec 7, 2006 | 03:21 PM
Rywire's Avatar
Default Re: (zenon8890)
rich as fawk! I sure dont suggest it!
Old Dec 8, 2006 | 04:39 PM
Default Re: (droppedcrxsi)
you can definitely ground the knock sensor and it will not through a code
racingant
Sep 10, 2005 05:34 PM
EG6[B16A1]
Oct 19, 2003 11:22 AM
EF_LSVtec
Feb 21, 2003 07:59 AM
1.8EG-T
Nov 5, 2001 12:08 PM
