Timing Belt Question
Old May 10, 2002 | 02:35 PM
Integra-T's Avatar
Default Timing Belt Question
Whats up everyone. I have a LSVTEC and I am wondering what timing belt to use. I have a B16 oil pump and water pump on the engine. I have a GSR timing belt on it as well. The thing about the GSR belt is that when I turn it the normal rotating way (counter clockwise) its fine but if I turn clockwise it skips a tooth. I know why it is doing this, its because the belt has tension on one side. Now I have been told to use the GSR belt if using a VTEC water pump. This seems odd to me because when the motor was just an LS I could turn the engine either way and it wouldnt skip. Should I be worried about this and get a new timing belt? Or is there no need to worry since the engine doesn't rotate that way anyway? Thanks in advance for your advice.
Old May 10, 2002 | 03:35 PM
Rocket's Avatar
Default Re: Timing Belt Question (Integra-T)
The rule is if you run the B16/B18C water pump then you run the B18C timing belt. The Vtec water pumps have bigger spocket and turn slower per crank revolution.
You're right it shouldn't skip a tooth when turning either way.
Also, you shouldn't turn your motor clockwise (backwards) too often. The cams are directional.
[Modified by Rocket, 12:35 AM 5/11/2002]
Old May 11, 2002 | 02:21 AM
Integra-T's Avatar
Default Re: Timing Belt Question (Rocket)
Thanks man. Anyone else have any thoughts/input on this? Much appreciated. TIA
rick_rabies
Apr 1, 2009 12:59 PM
vw eater
Jun 9, 2006 07:49 PM
LSVtechnologytur...
May 9, 2005 10:19 PM
BoOsTiN Dc2
Feb 7, 2004 04:49 AM
infamousALLMTR
Feb 25, 2003 07:17 PM
