Brake Question.
This is not a Honda question. It pertains to my 92 Mazda B2200.
It is pulling hard to the left when I brake. The alignment is fine because I can let go of the wheel and I will continue to go straight. I am thinking I have a bad passenger side caliper. Does this sound accurate?
Guest
Posts: n/a
check both driver and passenger-side brake pad and rotor. if the driver side is noticabley more worn than the passenger- try adjusting your passenger-side brake pressure (10mm nut on caliper)!!! if no difference you might have a fualty caliper. (this happen to me before)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civicboisi »</TD></TR><TR><TD CLASS="quote">Check the Caliper, Caliper slides, brake hose.</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jimjonez »</TD></TR><TR><TD CLASS="quote">check both driver and passenger-side brake pad and rotor. if the driver side is noticabley more worn than the passenger- try adjusting your passenger-side brake pressure (10mm nut on caliper)!!! if no difference you might have a fualty caliper. (this happen to me before) </TD></TR></TABLE>
Thanks guys, I will check tomorrow. I have owned this vehicle for a year and the only thing I have done is replaced the belt. That was easy No a/c no P/S.
About a month ago I hit a deer. The truck is super light so it does not take much to stop it. When I hit the deer I locked up the brakes and I am guessing that is why is caused the caliper problem. I know I did not have this problem before I hit the deer.
https://honda-tech.com/zerothread?id=1792416
Thanks again I will post my results.
proudcss
Honda Civic (2001 - 2005)
Dec 27, 2007 07:42 AM
