how can i get my crank pulley off.
Old Dec 6, 2006 | 11:46 AM
Bullet113's Avatar
Default how can i get my crank pulley off.
Im putting my car back together after breaking a timing belt at 6k rpm. and so i've put omni power valves in and replaced all the old belts (car has been sitting for six months) and now i need to put on the new timing belt, problem is i cant get my crank pulley off to completely remove all that plastic covering from around the bottom timing gear. i've tried putting a long wrench on it and all it does is move the pistons up or down half an inch and then when i stop putting pressure on the wrench they go back to where they were before. Help i have no clue how to get this crank pulley off or how to get the belt on w/o removing the crank pulley....
Old Dec 6, 2006 | 11:50 AM
-Darren-'s Avatar
Default Re: how can i get my crank pulley off. (Bullet113)
you need one of these and some strength because that bolt is on tight:
http://www.monstermarketplace.....html
Old Dec 6, 2006 | 11:55 AM
jacobolito's Avatar
Default Re: how can i get my crank pulley off. (-Darren-)
haha good luck. i once took my block all the way to the shop. carried it inside (that thing weighs like an *itch) and with a power air rachet took it off.
Old Dec 6, 2006 | 11:56 AM
Deluzional's Avatar
Default Re: how can i get my crank pulley off. (jacobolito)
power tools
Old Dec 6, 2006 | 11:59 AM
Bullet113's Avatar
i've seen those before, how do they work?
Old Dec 6, 2006 | 12:01 PM
Bullet113's Avatar
and im not talkin bout the power tools, to me it just looks like two wrenches and one has an adapter or somethin on it...
Old Dec 6, 2006 | 12:21 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
The "adapter" you see is a Honda crank pulley tool. It fits in the hex-shaped space in the crank pulley to hold it in place while you use a breaker bar w/ 19mm socket to remove the bolt. It runs about $50-$60 I think.
I actually used an impact wrench to remove the bolt, and then used the crank pulley tool to hold the crank in place while I torqued the bolt to 134 lb-ft with my torque wrench.
Old Dec 6, 2006 | 02:29 PM
Code Blue's Avatar
Default Re: (PatrickGSR94)
yea you can use those for hand tools. I've been using my cordless matco impact gun
w00t w00t
Old Dec 6, 2006 | 03:05 PM
ozzyman's Avatar
Default Re: (Code Blue)
You wont be able to get the timing belt on without taking off the crank pulley.
If you go to Napa or Schucks or a tool truck you can purchase a 'chain wrench'. Its basically a bar with angled teeth at the end and a bike chain. You wrap the chain around the pully and the teeth hold the pulley and the chain tightens as you try to loosen the bolt. VERY affordable and a good tool to have. Its pretty universal so you can use it on other pulleys as well.
Old Dec 6, 2006 | 08:10 PM
Community Builder
have you used that chain wrench before to hold the crank pulley? That looks like it could damage the ribs on the pulley for the belt.
Old Dec 6, 2006 | 09:06 PM
ozzyman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PatrickGSR94 &raquo;</TD></TR><TR><TD CLASS="quote">have you used that chain wrench before to hold the crank pulley? That looks like it could damage the ribs on the pulley for the belt.</TD></TR></TABLE>
Plenty of times. Recently used it to put together my fully built H22 bottom end. It puts tiny little knicks on the lip of the pulley but it doesnt touch the belt at all. Not enough to throw it off balance either. Works great and doesnt cost a small fortune like a Matco cordless impact.
Old Dec 7, 2006 | 12:46 AM
SYNSEI's Avatar
Default Re: (ozzyman)
After trying for a few days, I just ended up taking my block to the shop up the street from me. I asked the guy to help me out because I didnt have an impact and he was cool. Glad I did because even with the impact gun, it was bitch to get off.
Old Dec 7, 2006 | 02:19 AM
Thizzed Out's Avatar
Default Re: (SYNSEI)
next tool to buy. pully remover..their pretty cheap
Old Dec 7, 2006 | 06:23 AM
gsrclan's Avatar
Default Re: (Thizzed Out)
Amazon sells the pulley tool for around 25 bucks.
Old Dec 7, 2006 | 06:41 AM
gsrclan's Avatar
Wrap a piece of leather around the pulley. I have the same thing but never used it. When the times comes to change the t belt on my wife's corolla I may need it.
Old Dec 7, 2006 | 06:56 AM
Sam92Teg's Avatar
Default Re: (gsrclan)
http://amazon.com/s/ref=nb_ss_...+tool
There are 3 tools on this page that will work, and one is only $15. You will need two breaker bars tho, unless you want to risk breaking your ratchet.
I have the $24.99 tool and worked great.
Old Dec 7, 2006 | 08:24 AM
Community Builder
Default Re: (Sam92Teg)
oh snaps! I didn't know you could get them for that cheap. Heck yeah I need to get me one of those (the $25 one) before the next time I change my timing belt (only 30K miles to go until I change it again at 270K miles ).
Old Dec 7, 2006 | 09:22 AM
gsrclan's Avatar
Becareful about the $15 one, it may not be be the right size.
Old Dec 7, 2006 | 09:33 AM
gsrclan's Avatar
If you work on cars a lot then get a good electric impact wrench. I bought a Milwaukee electric impact gun rated 300 ft.lbs. I took the pulley nut off with it in&lt;5sec. It may not have as much power as some air guns but it's more convient and take much less spaces.
Old Dec 7, 2006 | 09:58 AM
Bullet113's Avatar
Thanks guys, im going to buy the 25 buck one and get it done, i'll post up a how to later on...
Old Dec 7, 2006 | 12:18 PM
reno96teg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by -Darren- &raquo;</TD></TR><TR><TD CLASS="quote">you need one of these and some strength because that bolt is on tight:
http://www.monstermarketplace.....html</TD></TR></TABLE>
i broke my crank pulley bolt free in no time with that tool, 2 breaker bars, and a long pipe over one of the breaker bars.
definitely a must have.
Old Dec 7, 2006 | 12:43 PM
IntegraType-R's Avatar
if u can't get the above tool, stick a allen wrench in your flywheel to where it catches itself on the tranny bell housing..and use that as a leveler to put pressure on the wrench..i've been doing this when i did have my "Star" tool..it works great, i've even seen some shops do it this way as well...
I've yet to see a flywheel or Allen wrench break this way but i wouldn't recommend this on a lighten flywheel.
Old Dec 7, 2006 | 02:16 PM
Dynasty21's Avatar
From: Where We Squeeze 1st N Ask Questions Last, CA, USA
Nice! Very informative!
EdSales
Jan 15, 2012 02:01 PM
Randysi
12
Oct 20, 2011 03:00 AM
EG6 Love
Mar 18, 2008 05:33 PM
dfabulous
10
Dec 9, 2007 11:00 PM
1994CivicGS-R
Mar 19, 2006 08:06 PM
