coilovers vs springs?
Old Dec 6, 2006 | 11:44 AM
SupraRXZ's Avatar
Default coilovers vs springs?
besides the adjustable ride hieght what does coilover have over springs? and for the price which is better?
Old Dec 6, 2006 | 11:46 AM
CRX Toad's Avatar
Default Re: coilovers vs springs? (SupraRXZ)
What are you going to be doing with the car? If this is a DD you will be fine with springs. I have coil overs on my car to adjust at the road course if I need to.
Old Dec 6, 2006 | 11:50 AM
STREETWERKZ's Avatar
Default Re: coilovers vs springs? (CRX Toad)
it also depends on what type of "coilovers"
lowering spring?
coil sleeves?
full coilovers?
Old Dec 6, 2006 | 11:52 AM
SupraRXZ's Avatar
I was thinkin about true coilovers or maybe nuespeed springs with koni struts
and i would be using it DD and sometimes on the track (couple of times a year, so not so much)
Old Dec 6, 2006 | 11:56 AM
Default Re: (SupraRXZ)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SupraRXZ &raquo;</TD></TR><TR><TD CLASS="quote">I was thinkin about true coilovers or maybe nuespeed springs with koni struts</TD></TR></TABLE>
full coilovers usually have a lot of adjustment. you can also custom order the springs to your specific spring rates too.
neuspeed springs have two off the shelf spring rates, race and street versions. non adjustable height. koni struts have adjustable dampening also.
if this is a street driven car, with no plans to hardcore roadrace, the spring/strut combo would be a decent more cost effective move. i mean, you're still buying quality parts too. not some ebay knock off.
Tyson's Avatar
please dont use the term "TRUE" coilovers.
theres nothing TRUE about them, nor conversely FALSE about anything else.
full coilover kit suffices. since it comes with shock and spring. its really a fully theaded shock body with spring kit.
GC is an adjustable spring kit.
Old Dec 6, 2006 | 11:57 AM
CRX Toad's Avatar
I am partial to a Koni and Sleeve Coil over setup that is just my opinion.
Old Dec 6, 2006 | 11:58 AM
Default Re: (Tyson)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tyson &raquo;</TD></TR><TR><TD CLASS="quote">please dont use the term "TRUE" coilovers.
im just trying to keep it a little more clear for the kids thinking the ebay sleeves are quality coilover setups. i know the english language, and understand what you are getting at.
i will change it to "full"
Old Dec 6, 2006 | 11:59 AM
mike-y's Avatar
springs + good shocks/struts (in this case, the konis) will be perfect for you, and better than a cheap set of coilovers. they will most likely ride better too.
Old Dec 6, 2006 | 12:03 PM
Tyson's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SupraRXZ &raquo;</TD></TR><TR><TD CLASS="quote">besides the adjustable ride hieght what does coilover have over springs? and for the price which is better?</TD></TR></TABLE>
springs.
some outdated info, but its still relevant.
http://www.norcalcrx.org/tyson/coilover.html
WOW, i really do need to edit the content now. THIS certainly isnt true anymore... i was referring to moton and JRZ and ground control advance design. not the omnipicskankd2club generic crap.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">A more proper term should be "full coilover". Typically (not always) these shocks are of better quality than off the shelf shocks like Koni and Tokico </TD></TR></TABLE>
JrEk9
Suspension & Brakes
19
Nov 24, 2009 02:26 PM
masijdm
May 18, 2008 02:26 PM
yobbr5
Honda Civic (2006 - 2015)
12
Oct 24, 2007 01:43 PM
TANGO28
Suspension & Brakes
Oct 10, 2006 10:14 AM
DRxCIVIC
11
Apr 22, 2002 09:33 PM
