is a .70 a/r to4s compressor too big?
Old Dec 6, 2006 | 11:00 AM
jameelrose's Avatar
Default is a .70 a/r to4s compressor too big?
i need some help deciding on which turbo would be best for my setup.
heres a run down of my setup.
ls vtec.
81.5 mm bore
approx~ 9.7:1 CR
wiseo pistons
eagle rods
stock gsr head
3" downpipe
3" thermal exhaust
my previous turbo was a turbonetics .70 to4s compressor 4" inlet, 2.5 outlet
turbine was a stage 3 .48 a/r
this turbo took a **** so im replacing it with a master power unit.
my goal is approx 350- 400 hp the most
my question is should i stick with the super huge to4s compressor or should i get a smaller compressor for my setup?
btw, i stepped up the turbine from .48 to .63 a/r.
thanks for the input.
Old Dec 6, 2006 | 11:09 AM
F20Cteg's Avatar
Default Re: is a .70 a/r to4s compressor too big? (jameelrose)
The compressor A/R or size has very very little to do with how the turbo behaves.
It does decrease inlet restriction though by having the bigger inlet.
Old Dec 6, 2006 | 02:01 PM
jameelrose's Avatar
so stick with the big compressor?
Old Dec 6, 2006 | 05:23 PM
blackeg's Avatar
it will be fine, i had a very similar setup with the same size turbo, it was a 5000-8500 rpm powerband
Todallybuilt
Nov 18, 2015 04:41 AM
Kid-jdm-teggy
May 1, 2014 04:48 AM
jetlude
Oct 10, 2007 02:14 PM
shermanyang
Mar 19, 2003 07:13 PM
i3oricua
Feb 21, 2003 07:49 PM
