HELP!!! Car counds like dirtbike, running rich as hell, cant figure it out?!
Ok i finally got my swap running but its running like a dirtbike or a snowmobile, loud, shaky, it almost sounds like the exhaust is coming out the shortram intake its so loud...
The plugs were pitch black when i pulled them but compression was solid (180 across). what could it be?
Im thinking my cam timing may be off a tooth? what would that soundlike?
Well okay start with the basics. You know you have enough fuel. Pull ALL your plugs and see if they are ALL black or just some? Sounds like its running off of 2 or 3 cylinders.
cap and rotor are like brand new, ive tried 2 dizzies both are in the same condition... but for some reason i also cant get a good read on the ignition with a timing light
all stock- i got it running pretty well just the header is leaking like crazy at the head flange and where it meets my exhaust so it sounds like a racecar
are all bseriers bolt patterns the same for the header? like b16 b18 are interchangeable
Sounds like it might be off one tooth. Pull off the valve cover and check valve timing to be sure. once you are sure procede with other component trouble shooting.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RedB20DA »</TD></TR><TR><TD CLASS="quote"> And also if you were a tooth off on the timing it wouldnt run at all.</TD></TR></TABLE>
It will run one tooth off on the cam gears, and it will sound just like he described. I had a friend who's car sat up for 6 weeks because he couldn't figure out why it ran like crap and sounded loud. First thing I checked was his cam timing, it was off two teeth on the exhaust cam and one on the intake cam but still ran. I set it right and back to running perfect. Make sure the cams and crank are in proper alignment.
i iwll get pics of the cam timing today to make sure (pics of cam and crank at tdc with valve cover off)
its snowing and im at work now but i will get pics on my next break
ok yeah i think both cam gears are off like 3 teeth in the same direction...
i may have been reading the crank wrong
does the LS crank have more than 1 white mark?? I see one white mark before the 3 red, and one after... but using the "socket extension in teh #1 cylinder" trick i determined the correct white mark to be the one AFTER the red marks.
I currently have it timed to read the one BEFORE the 3 red marks
FIXED!
redid the cam timing, and valve lash after that. Fired it up and ran a lil rough the first fews minutes, it kept starting and reving up and dying, finally i got it to stay idling on the 3rd start and kept it alive by giving it throttle from the bay, after about a min of that it leveled out.
SOUNDS MEAAANN
waiting for my new alternator then ima take this for a drive
thanks all
SOUNDS MEAAANN
thanks all
ok so im throwing a code 9 - #1 Cylinder position whats that mean?
the car wont hold idle on cold start i need to keep reving it then it will eventually hold idle on its own. Whats this code mean?
x4thGenCafe
15
Apr 18, 2008 06:15 PM
