Why is my rpm needle jumping around like crazy?
i have a gsr and it is actually stock right now...even wen it was turboed i had the same problem. Once in a while the rpm needle will be off and will jump around like a guitar tuner...wat can be wrong? any help will be much appreciated. thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JasonST »</TD></TR><TR><TD CLASS="quote">Did the car bog or engine cut out at all when it was jumping or was it just jumping around while the car seamed fine?</TD></TR></TABLE>
jumping around wen the car seemed fine
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jthm »</TD></TR><TR><TD CLASS="quote">Have you touched the Ecu? I had the same problem and it was a ground to my Ecu.</TD></TR></TABLE>
the ecu has been tapped to a vafc but the vafc is set at 0
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crx_88_si »</TD></TR><TR><TD CLASS="quote">crazy tach = bad ignitor.</TD></TR></TABLE>
for this man
for this man
