MINI-ME HELP
Old Dec 5, 2006 | 05:33 PM
Y_my_91's Avatar
Default MINI-ME HELP
i was wonderin what kind of timing belt do i use with a d16a6 block and a d16y8 head i already forgot
Old Dec 5, 2006 | 05:36 PM
dr_latino999's Avatar
Default Re: MINI-ME HELP (Y_my_91)
D15B7 Timing belt.
Reference - https://honda-tech.com/zerothread?id=1461961
Old Dec 5, 2006 | 06:47 PM
1990si's Avatar
haha yes the mini me swap
Old Dec 5, 2006 | 08:06 PM
njn63's Avatar
i used a y8 timing belt and i was fine *shrugs*
a6 block, y8 head, a6 tensioner
Old Dec 5, 2006 | 08:12 PM
Default Re: (njn63)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by njn63 &raquo;</TD></TR><TR><TD CLASS="quote">i used a y8 timing belt and i was fine *shrugs*
a6 block, y8 head, a6 tensioner</TD></TR></TABLE> Well you could use it, but then your timing belt will be applying a whole slew amount of unnecessary tension on all the components it touches.
Old Dec 5, 2006 | 08:21 PM
1990si's Avatar
Default Re: (dr_latino999)
yea i used the y8 timing belt also with the y8 tensioner. ran perfect.
Old Dec 5, 2006 | 08:22 PM
1990si's Avatar
Default Re: (1990si)
was not too tight either
Old Dec 5, 2006 | 08:24 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1990si &raquo;</TD></TR><TR><TD CLASS="quote">yea i used the y8 timing belt also with the y8 tensioner. ran perfect.</TD></TR></TABLE> You got the Y8 tensioner to bolt up fine and dandy to the A6 block?<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1990si &raquo;</TD></TR><TR><TD CLASS="quote">was not too tight either</TD></TR></TABLE> The only reason the belt is usually too tight is the diameter of the A6 tensioner is quite a bit larger.
Old Dec 5, 2006 | 08:29 PM
1990si's Avatar
yea i believe the tensioner bolted right up. not sure. i did the swap a while ago now. I believe the z6 tensioner is different than the y8 one. and the z6 one doesnt fit right on the a6 block. dont quote me though its been a while.
Old Dec 5, 2006 | 08:32 PM
You're correct, the Z6 tensioner will not bolt up the A6 block, so it would be safe to say the Y8 and A6 share the same mounting package, just different diameter pulleys. I wish I had a Y8 tensioner laying around when I built my A6 mini-me.
Old Dec 5, 2006 | 08:34 PM
1990si's Avatar
Yea it actually came with the timing belt. i also have a new one ill sell. 15 shipped.
Old Dec 6, 2006 | 07:40 PM
Y_my_91's Avatar
thanks guys. i ll post some pics of my car when i get done still in the shop just got painted its an eg. custom color. pretty nice
byrne_06
10
Aug 3, 2010 12:56 PM
StupidSlowRSX
Feb 15, 2008 03:00 AM
julio_bOostamante
Sep 21, 2005 07:59 PM
lohatch
Jun 15, 2004 07:44 AM
lohatch
Jun 13, 2004 05:45 PM
