spoon stoker kit
It will NOT work on a b16a because the deck is shorter than the b16b. that is why the b16a has the same bore as all the other b18's but is only a 1.6 the pistons will hit the head....
B16B is the same block as a GSR or ITR. it has a different crank.
it is NOT the same as a traditional B16.
if you want a cheap stroker, buy 93 integra GSR crank and rods. it'll put you at 1.7L, bore out the cylinders, and you could have a 1.8L
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by STREETWERKZ »</TD></TR><TR><TD CLASS="quote">B16B is the same block as a GSR or ITR. it has a different crank.
if you want a cheap stroker, buy 93 integra GSR crank and rods. it'll put you at 1.7L, bore out the cylinders, and you could have a 1.8L </TD></TR></TABLE>
DOH! but good info, i always thought the b16s were exactly the same
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blue. »</TD></TR><TR><TD CLASS="quote">same engine, just different year. b16b OBD2 hydro tranny, b16a obd1 cable tranny... same everything else. Good luck sounds out of my price range
PLEASE DO NOT POST IF YOU ARE NOT 100% ON YOUR ANSWER!
</TD></TR></TABLE>PLEASE DO NOT POST IF YOU ARE NOT 100% ON YOUR ANSWER!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HatchMo »</TD></TR><TR><TD CLASS="quote">
x10
x10
willyboyK20
Feb 22, 2005 08:26 PM
ntensehonda
18
Mar 3, 2004 08:35 PM
