Metal scraping sound in wheel
Old Dec 5, 2006 | 06:14 AM
canooten's Avatar
Default Metal scraping sound in wheel
Wonder if someone can give a diagnosis....
Have a 98 Civic LX. Was driving to work this morning and as soon as I get on the road I start hearing this metal on metal scraping sound coming from the front right wheel. One of those horrid nails-on-the-chalkboard sounds that makes you want to expel pea soup from your mouth.
It's the worst from about 30 - 50mph. Faster than that it either stops or gets so fast and high pitched that I can't hear it any more. Slower than that it's really not noticable.
Car is driving fine....it's not pulling and I can't "feel" the noise in the wheel.
Old Dec 5, 2006 | 06:21 AM
eddie_ek's Avatar
Default Re: Metal scraping sound in wheel (canooten)
Check your brakes or wheel bearrings
Old Dec 5, 2006 | 06:27 AM
hondaman86's Avatar
sounds like wheel bearing, jack the car up and check for play.
Old Dec 5, 2006 | 07:34 AM
cranny's Avatar
24.224.233.247
Default Re: Metal scraping sound in wheel (hondaman86)
no wheel bearing would be the opposite , you wouldnt hear it until highway speeds , it would howl. sounds like you either need brake pads , or your dust shield is getting rotten , comming loose and rubbing your spindle.
Old Dec 5, 2006 | 07:35 AM
B16B_coupe's Avatar
HRD PKR
Default Re: Metal scraping sound in wheel (cranny)
sounds like the backing plate is hitting the rotor
Old Dec 5, 2006 | 07:52 AM
MidwestSiR's Avatar
i'll third the dust shield thing
sometimes they get bent and ride the rotor. Check the back of your rotor while you're at it for scrapes or gouges
Old Dec 5, 2006 | 09:13 AM
fms1day's Avatar
Default Re: (MidwestSiR)
I'll fourth the dust shield... you may just have to knock it back a little to get it away from the spinning brakes and wheel..
Old Dec 5, 2006 | 10:11 AM
AntiStock's Avatar
Default Re: (fms1day)
I 5th it...lol I've had this happen more than a few times with some of my past cars. Jack the car up and spin the wheel with your hand. You should be able to hear exactly where it's coming from.
Old Dec 5, 2006 | 12:41 PM
canooten's Avatar
Sounds like the dust shield then. I'll jack it up and see if I can locate where it's making contact.
Thanks for the tips.
Old Dec 5, 2006 | 01:25 PM
BiffStroganoffsky's Avatar
I had a rock (pebble) get lodged between the rotor and shield which made it screech like I had run the pads down to the metal. You might be lucky and just find something wedged in there.
Old Dec 5, 2006 | 01:34 PM
cwf1988's Avatar
Default Re: (BiffStroganoffsky)
new pads and check dust plate same happen to my 99 lx
Old Dec 5, 2006 | 01:41 PM
spoonef's Avatar
Default Re: Metal scraping sound in wheel (eddie_ek)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eddie_ek &raquo;</TD></TR><TR><TD CLASS="quote">Check your brakes or wheel bearrings</TD></TR></TABLE>
Old Dec 6, 2006 | 07:07 AM
canooten's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">I had a rock (pebble) get lodged between the rotor and shield which made it screech like I had run the pads down to the metal. You might be lucky and just find something wedged in there.</TD></TR></TABLE>
There's always that possibility. I live on a gravel road. I'll check that as well.
Old Dec 7, 2006 | 05:06 AM
canooten's Avatar
Looks like the lodged rock takes it. At least it seems that way.
Was backing out of the driveway last night to take the car to my dad's garage to check it out and it was scraping like mad in reverse. When I got into the road, shifted to drive and started forward, I heard a rattling sound like something was falling inside the wheel. Seems that changing directions a few times dislodged the rock and it came free on it's own.
Still took the wheel off and checked it out. No damage to the rotor, and no noises today so I guess it was no big deal.
Thanks for the rock tip.
mouab18c1
Aug 2, 2014 12:21 AM
EK_MaGz88
Mar 17, 2011 02:32 AM
JDMhatchback20
May 6, 2007 06:40 PM
o0Jash0o
Sep 28, 2006 09:22 AM
carbonlaced
Jun 27, 2006 10:02 AM
